Results 1 to 3 of 3
    New ROGer Array
    Jan 2017
    5
    Z370-E --> T_Sensor not working
    UPDATE: I eventually got T_Sensor working at some point while hard-resetting CMOS and re-flashing the BIOS.
    The T_Sensor external temperature sensor doesn't seem to be working on my motherboard. Can anyone confirm whether this is just my board or more a wide-spread problem? From past experience my guess is this is probably a ASUS EC / BIOS problem on all Z370 boards.
    Originally the sensor included with the Z370-E motherboard was zip-tied hanging in the case monitoring ambient temperature got a reading of 29.8C. Since this seemed to be a reasonable reading, I assumed it was working.
    While overclocking, I began to see 'Motherboard VR Thermal Throttling=Yes' in IXTU. I verified that the VRM heatsinks were getting too hot with an infared thermometer. Under load they are nearing 100C in places on the outside of the heatsink with semi-good airflow so the VRMs themselves must be quite a bit hotter. This is a water cooled system, so it might not be getting really good airflow over the VRM heatsinks.
    To address this issue, I added a 120mm fan (powered by rear exhaust fan via Y cable) to blow over the VRMs, taped the T_Sensor probe between the fins of one of the VRM heatsinks, and in the BIOS set the rear exhaust fan (and VRM fan connected via Y cable) to throttle up as temperature rises. The problem is that this had no effect on fan speed.
    Investigating, I found that the output of T_Sensor will not change from that 29.8C reading no matter what, load or idle. I assume this isn't a software / driver issue since I get the same 29.8C reading in the BIOS and in Windows.
    Suspecting this may be a defective thermal probe, I replaced it with an aftermarket unit (XSPC Wire Sensor 10K) and taped it down to the heatsink with foam tape to make sure it's getting an accurate reading but I get the same exact 29.8C reading even though the infared thermometer reads 80-90C nearby on the heatsink.
    (By the way, what ever happened to the VRM_Temp sensor that was built into the motherboard in the Z170 and Z270 series boards?)
    Currently I'm working around the problem by using CPU temp to throttle the fans, but this is annoying because it throttles the fans too aggressively. This DOES fix the VR Thermal Throttling issue, but I'd really like these fans to spin up only when the VRMs start getting hot.
    Either I'm doing something wrong, this is this an ASUS EC / BIOS issue or is my motherboard defective?
    ROG Enthusiast Array mikex999 PC Specs
    mikex999 PC Specs
    MotherboardAsus Z370 F-Gaming
    Processori7 8700k
    Memory (part number)CMK16GX4M2E4000C19R
    Graphics Card #1Zotac 1080 Amp! Extreme
    MonitorDell S2716DG
    Storage #1Samsung 970 evo 512gb
    Storage #2Samsung 950pro 256
    CPU CoolerCorsair H150i Pro
    CaseFractal Design Define TG
    Power SupplyBe quiet straight power 750w
    Keyboard Corsair K70 Platinum Rapidfire
    Mouse Corsair Vengeance m95
    OS Windows 10
    Network RouterAsus RT AC88U
    Dec 2015
    38
    the same for me
    ROG Member Array lilorcarmy PC Specs
    lilorcarmy PC Specs
    MotherboardAsus ROG Maximus VII Impact
    ProcessorIntel Core I7-4790K
    Memory (part number)F3-2400C10D-16GTX
    Graphics Card #1STRIX-GTX980TI-DC3OC-6GD5-GAMING
    MonitorBenQ XL2420G
    Storage #1Samsung EVO 840 120GB SSD
    Storage #2Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB
    CPU CoolerCorsair H100i GTX
    CasePhanteks Enthoo EVOLV ITX
    Power SupplyCooler Master V850
    Keyboard Corsair Strafe RGB
    Mouse Logitech G502 Proteus Spectrum
    Headset Razer Hammerhead Pro
    Mouse Pad SteelSeries QCK mini
    Headset/Speakers Xfree XE222
    OS X17-59465.iso – Windows 7 Ultimate SP1 Media Refresh
    Network RouterCisco DPC2320 Cable Modem
    Accessory #1 Samsung SM951 128GB NVMe MZVPV128HDGM-00000 M.2 80mm PCIe 3.0 x4 SSD - OEM
    Accessory #2 Deepcool RGB Color LED
    Feb 2015
    8
    Quote Originally Posted by carn4ge View Post
    Hi mate, sorry for bumping up this post. We have same mobo and I just started exploring overclocking capabilities of this mobo. Can you post an image showing how you taped the t_probe onto one of the fins of the heatsink? btw. im gonna be using the included 40/50mm fan bracket to cool down the vrms.
