Results 1 to 7 of 7
    New ROGer Array
    Mar 2018
    3
    Need help with choosing laptop for WoW Legion/Battle for Azeroth
    Hello everyone.
    I need help with some laptops that will satisfy my needs.
    First I don't have much money so I will only post laptops that I can buy from some friends that are offering me a good deal.
    I only play world of warcraft legion and when it comes out battle for azeroth and use laptop for movies, web surfing, office etc.
    I would like to buy a laptop that will run WoW Legion/BFA on medium or if needed low settings but without any bugs/lags or anything, FPS 50+ at all times. Resolution doesn't have to be high either.
    Laptop A:
    i7-3610Q
    GT 650M 1GB
    DDR3 8GB RAM
    SSD 120GB
    Laptop B: (little bit cheaper than A)
    i5-3230M
    GTX 660M 2GB
    DDR3 8GB RAM
    SSD 120GB
    Which one would be better and can it run WoW like I said?
    https://prnt.sc/iv5hss
    https://prnt.sc/iv5hxe
    Thanks a lot!
    Last edited by Nikola405; 03-23-2018 at 02:30 PM. Reason: added something that I forgot
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,722
    Well, if you are getting these machines from friends I would just ask them if you could borrow it and try it out to see if it will work for what you need.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Mar 2018
    3
    Thanks for reply. Not really that kind of friends and they are not even in the same city.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,254
    Look up both GPU models on Notebookcheck. There's a benchmark with World of Warcraft.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,722
    Those are older and lower spec'd machines so you may have to make a sacrifice somewhere. The better GPU is going to allow better graphics settings. If you don't care about visuals then you can probably get away with turning down the settings with the 650. A quad core with a higher turbo is going to be better than the dual core at supporting lots of stuff going on during raids & such.
    New ROGer Array
    Mar 2018
    3
    I will be playing if needed, on lowest settings, turning off everything and with lower resolution 1366x768. I just want to have good FPS in raids... I want good FPS at all times Knowing this, you are saying that it would be better to have laptop A? Thanks
    But also to satisfy battle for azeroth
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,722
    Yes, I do not play WoW but my understanding is that they make it so that it can run on almost any system with reduced graphical settings. They can't really reduce the CPU usage from stuff like player interactions, just the visual effects. So my understanding is that you don't need a great graphics card but you need a decent CPU and internet connection.
