Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 51
    ROG Guru: Yellow Belt Array Asryan PC Specs
    Asryan PC Specs
    MotherboardAsus Maximus Hero X
    Processor8086k / 5GHz / delidded
    Memory (part number)32GB G.SKILL Trident Z RGB / 3466Mhz
    Graphics Card #1GTX 1080 TI EVGA FTW3
    MonitorASUS PG34Q - 34" GSYNC
    Storage #1SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500Go
    Storage #2HDD: WD Green 2To 64Mo 3.5"
    CPU CoolerCorsair H150i + ML 120 Pro
    CasePhanteks Enthoo Luxe tempered glass
    Power SupplyCorsair RMI 850 GOLD
    Keyboard Corsair k70 rapidfire
    Mouse Logitech G900 Chaos Spectrum
    Headset Logitech G933
    Headset/Speakers G560 Logitech
    OS Win 10 60 bits
    Oct 2016
    14
    130
    Maximus X hero / i7 8700K settings?
    Hi there,
    I installed yesterday a maximus X hero, 8700K and Trident Z RGB
    I have an Eisbaer AIO LT 360
    I was quite surprised by the temps..
    Coming from a delidded 4790k which maxed out at 60 degrees (non oc) in game or stress test, seeing 70 degrees in Assassins creed origins and almost 80 in a 15 min real bench stress test ....
    I plan to delid my 8700K tonight (a friend will do it for me with the dedicated tool)
    But i have some questions about tweaks and bios settings to get the best of it (without oc for now) and reduce heating.
    First, are those temps normal? I read everything and its opposite about it and some people on FB groups claims to have a 8700K running 60 degrees max without delid and on an AIO.
    about vcore.
    Do you set vcore auto or manual? If manual, what value ? I considered putting 1.20 but maybe i can go lower?
    I deactivated Asus multicore enhancement and so i have :
    1 active core : 47
    2 c: 46
    45
    44
    44
    43
    Is that ok?
    What are the other settings you could advice me to change to have a stable and less warm CPU?
    Thanks a lot.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Asryan,
    The Eisbaer AIO's are supposed to be pretty good coolers, after your delid (if it's done correctly with LM) your system should run 10 to 20 degrees cooler.
    CPU quality and required voltage vary quite a bit so every system needs tuned individually
    At default settings 1.18 to 1.2 volts should be enough , but your CPU will determine that
    Please list your components, memory part number helps if you are going to use XMP or overclock the memory
    What are your expectations, are you planning on overclocking your CPU, memory? and if so by how much
    ROG Member Array Velcade PC Specs
    Velcade PC Specs
    MotherboardROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard
    ProcessorIntel - Core i7-8700K 5.0GHz 6-Core Processor
    Memory (part number)G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory
    Graphics Card #1GeForce GTX 1080 STRIX-GTX1080-A8G-GAMING
    MonitorPG279Q ROG Swift
    Storage #1Crucial - MX500 2TB 2.5" Solid State Drive
    Storage #2Western Digital - Gold 4TB 3.5" 7200RPM Internal Hard Drive
    CPU CoolerFractal Design - Celsius S36 87.6 CFM Liquid CPU Cooler
    CaseFractal Design - Define R6 Gunmetal TG ATX Mid Tower Case
    Power SupplyEVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply
    Headset Sennheiser HD650
    OS Microsoft - Windows 10 Home OEM 64-bit
    Network RouterRT-N66U
    Accessory #1 Blue Yeti Microphone
    Velcade's Avatar
    Jan 2018
    16
    I've delidded my 8700K, OC'd to 5.0GHz and have the same mobo. My voltage is at 1.4V Vcore and -3AVX Offset. Cooled by a Celsius S36, Prime95 after 3 hours saw temps max out at 81. During normal game play (2k res, ultra graphics) I see temps max out at 52.
    As Menthol stated what are your PC specs and what is your end goal for the OC?
    Asryan PC Specs
    OS Win 10 60 bits
    Oct 2016
    14
    130
    Hey
    Well i mostly do gaming and some video editing for work.
    I don't plan to oc for now, delid and all is more about lower temps and SILENCE.
    But i was wondering if my temps were ok for that kind of CPU. if i get 20 degrees lower and have like 50 degrees in game max i'll be happy.
    Apparently Assassins creed origin is taking a lot from CPU and makes them really warm, i haven't tried other games yet.
    The guy who will delid it does good job, (with conductonaut inside and kryonaut outside) he delidded my 4790K without issues and i had really good temps
    In bios I just changed that :
    ASus multicore enhancement : off
    Vcore on manual mode : 1.2
    XMP profile for the ram.
    For my specs here they are
    Motherboard: Asus Maximus Hero X
    Processor: i7 8700k stock frequency /
    GPU : GTX 1080 TI EVGA FTW3
    Ram : 32GB G.SKILL Trident Z RGB / 3466Mhz
    PSU: Corsair RMI 850 GOLD
    Watercooling : Eisbaer LT 360 (I changed the fans for silent wings 3)
    Case : Phanteks Enthoo Luxe / 2 silents wings 3 140mm on the front for intake, one on the back for exhaust
    SSD
    Samsung EVO 850 - 500Go x 2
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    What are your ambient room temps, your system should idle at about 10 degrees over ambient, as you know from your Haswell system, the deild will make a huge difference.
    I am running my 8700k @ 5.2GHZ AVX -2 offset 1.4 volt, ambient temp around 22 degrees, idle temp around 32 degrees, Realbench load under 80 degrees
    I am using a 360 Corsair AIO, fans 600 rpm at idle, very quite, about 1200 rpm full load, fans connected to CPU fan header with spliter, not connected to AIO
    I am currently using an EVGA 1080 FTW2, I installed EVGA's AIO kit on the card, this made a huge difference in noise, my GPU is now almost silent during use
    Set SVID behavior to best case scenario, LLC 5 or 6
    Asryan PC Specs
    OS Win 10 60 bits
    Oct 2016
    14
    130
    I don't really know about ambient temps. I live in france so it's average but i guess 20 to 25 degrees in my room shoud be that
    Idle i'm around 35 but i noticed it spike to 45 without reasons too. Which is weird ?
    My realbench was around 80 degrees at stock without MCE but without delid, is that normal?
    What is avx?
    Svid? Should i keep it enable or not?
    i'll set up LLC at this level then. (if someone can explain LLC to me btw, never really got what it was used for)
    And for vcore, should i use manual then?
    For my fans, i maxed fan speed during gaming or video rendering (silent wings 2200 on aio, exhaust on the top, 1000 on the case exhaust and intake)
    My Fans are connected to a rheobus. The pump is on the cpu fan
    The eisbaer pump is set at 2300 / 2400 rpm not 2600 because i can hear it. I asked alphacool they told me doing a speed curve for it is fine so i did it, 100% at 60 degrees and like 80% below. (in bios)
  7. #7
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,788
    LLC is Load Line Calibration, it addresses Vroop (CPU voltage drop) while under load.
    Here's some more info:
    http://www.overclock.net/forum/8-int...c-do-bios.html
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
  8. #8
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    I think your RB temps are normal, if your using RB ver. 2.56 it uses AVX which will create more heat as it uses more current
    AVX is an instruction set for some specific work loads, it does increase current and heat, not an issue for most users, just set an AVX offset of 2 or 3 just in case
    As load increases and draws more current you will encounter vdroop, some vdroop is good, adjusting LLC level allows some control of this so you don't have to run vcore as high as you would without using LLC
    Your pump speed and fan speeds are good as long as you are comfortable with noise levels, I don;t use headphones so I prefer a low speed, low noise fan but this is always user preference
    My ambient's are similar to yours and cooling is very similar, I have my pump connected to the AIO header at full speed, rad fans connected to CPU header controlled by CPU temp
    your idle temp won't drop by much unless you run the fans at high speed after delid but your load temps should improve dramatically allowing either high clocks, lower fan speeds or a combination of the two
    I use adaptive vcore and balanced power plan myself for 24/7 usage, there a numerous threads about adaptive vcore in these forums
  9. #9
    Asryan PC Specs
    OS Win 10 60 bits
    Oct 2016
    14
    130
    Hello there,
    here are my results after delid of 15m on realbench.
    before delid, it was around 79 degrees..
    I'm pretty happy about it, what do you think.?
    i7 8700k @1.18v
    Maximus hero x
    AIO eisbaer LT 360 with silent wings high speed
    boost 4,7
    Cores
    47
    46
    45
    44
    44
    43
  10. #10
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Asryan,
    Good job, isn't it nice to see the lower temps
