Does ASUS G752VT have the same power issues as ASUS G750JZ
ajaXXX
My ASUS G750JZ I dead and probably beyond any reasonable repair.
Of course the power/charging module had failed. When it happened for a first time I had my motherboard replaced. Now laptop is after warranty and cost of replacing motherboard is horribly high (especially when you know it will fail after about 12 months).
I really wanted to buy something else but "unfortunately" ROG series apart that problem is a great laptop. So I am wondering about buying ASUS G752VT .
So do anyone of you know if ASUS G752VT suffers from the same problems because of poor quality power/charging module
6 REPLIES 6
Darnassus
Status Under Review
I had a G750JX for 4 years, no issue. Had the G752VS for 6 months roughly, no issue.. at least with power.
Clintlgm
Level 14
If you're looking at the VT model you might want to take a closer look at the G752VY model more powerful and very few issues that aren't self-inflicted things to look out for some VY came with 512GB SSD most were actually 2x256GB SSD in RAID mode your better off with 1 256GB and just buying a 512 GB later on. 32GB RAM is way more than is needed for any use other than running multiple VM The Model I got is the G752VY DH 72 with the latest BIOS/UEFI I have had Zero issues that weren't self-inflicted or Windows 10 related. these models VM VT VY are all 2 years + old now so keep that in mind.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
navis995
Level 11
Power issue that requires whole MB change?
YOu my friend got ripped off big time.
I myself was the victim of dead jack port for the G750JZ but I bought the new jack only and replaced it and now it works fine.
I can't see the reason to replace the whole board for a single power jack.
p.s. the reason for high cost is the cpu which is soldered on the motherboard.
Asus Rog G750JZ
Screen: 1920x1080 17.3'
CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
RAM: Samsung 32GB 1600MHz
Storage #1: Samsung Evo 840 250GB
Storage #2: Samsung Evo 850 500GB
Storage #3: Seagate Barracuda 2TB
Storage #4: Samsung Evo 128GB MicroSD
How did you test it to determine that its the jack and not your motherboard or were you just lucky and guessed right?
eandlau
I have an Asus G752VT and I have a possible power jack issue.
Power does run through the machine bu there is a clicking sound and the machine just turns off about two seconds after you plug it into AC.
Adapter is fine tested with multimeter.
However the power adapter is a cheaper "original" I bought off Amazon and much lighter than the original that I bought with machine.
The problem started one week after I began to use the new power brick.
I am now not sure if its the motherboard or the jack.
I ordered a new power board and replaced that part but same problem.
Any way I can determine if its the power jack and not the motherboard?
TY 🙂
eandlau wrote:
TY 🙂
Sounds like you got a cheap not compatible AC adapter that is causing your issues Being lighter is also is not suppling enough power to your computer
980m GTX 4 GB
Windows 10 Pro
Z97 -A
Windows 10 Pro
