Hey ya'll, I've had this board for about a week and the RGB has gone in and out for me. I seem to have two different issues, one very big and one not so big. The most annoying is the RGB LED's on the motherboard is on, but it is not detected by the BIOS or software. This means I cannot turn it off through BIOS when the computer is shutdown and I can't change the color profile with Aura.
The second problem is with my G. Skill TridentZ rgb ram. On startup the RGB on the ram is fine. But if my computer goes to sleep, the ram rainbow stops moving and is stuck on one color. Only a reboot helps. As I said this isn't a big problem but its something that is slightly annoying as I can't control the mobo leds to match the ram.
Thanks in advanced!
P.S. Running Bios 0612
I found this forum and saw the LED connector might not be on so tight so I corrected that. I put the motherboard back in the case, and the RGB still didn't work so I took it out again and realized pushing on the LED seemed to revive it a for a little while but it goes out again. After some trial and error I finally got the LED's to work in the case and show up in software for about 24 hours. Now, the board still has the stock rgb rainbow but it is not detected in BIOS or Asus Aura software.
