Hi Everyone,
My first post here. Be gentle...
I just purchased a new system - first one in about 8 years - i7 8700k with a Z370-G wifi mobo. As gpu prices are utterly insane at the moment, I figured that I'd live with onboard graphics for a while, until I can justify a purchase. The mobo has a HDMI output and a displayport output. I'd like to be able to use both simultaneously to run 2x monitors, but I can't for the life of me get the displayport to detect the monitor plugged into it.
Both monitors are old things, with a max pixel count of 1650x1050 and are DVI native. So I have one cable which is passive DVI-HDMI converter, which works fine. I have tried passive and active converters for the displayport side, neither of which has worked. I've discovered the graphics configuration page on the bios, and set primary display to intel, and igpu multi-monitor support to enabled, with no luck.
Could anyone give me a tip as to where to go from here? I'm getting annoyed with this one and have tried everything that I can think of for the time being, however I've been out of the game for a long time now so there may be some obvious tricks that I'm unaware of.
Much appreciated,
Kevin
