Spatha surface issues [Resolved]
ufoozgur
Hi there,
When I turned on my PC, Armoury told me that there was a firmware update for Spatha. I updated and now it's 1.69. I use my Spatha in wired mode. But after the update, the cursor is not moving at all. I changed the surface type (which was ROG Whetstone, the pad I am using) to ROG Sheath and cursor is moving just a tiny bit. I guess the new firmware has a bug with the calibration settings. Now I can't be able to use the Spatha.
Any help? I also tried to rollback to the 1.62/1.63 beta firmware (which is the only one on the support section), it says "Spatha is not connected", but it is and Armoury sees it. I can even change the RGB LEDs.
Browni
Try selecting a different profile by holding the dpi button down and then clicking one of the buttons on the left hand side of the mouse.
