1080TI Strix OC - Performance Issue + LED glitch?
Vaipan
SPECS: 6900K - 64GB RAM - Rampage V Edition 10 Mobo - 1000W PSU
Weird issue: I can control the colors in AURA except it seems the entire 'blue' hue doesn't work. By that, I mean that the GPU can cycle through the colors except for blue and any other colors in the blue spectrum. When I select blue in AURA, the GPU is green. If I select pink, the GPU is dark red. When I select white or turn down the saturation, the GPU is a yellow-green color. I uninstalled and re-installed AURA several times, along with all other Asus apps, and the motherboard displays the colors perfectly, but the GPU doesn't. The GPU accurately displays yellow, green and red.
Is there anything I can do?
Edit: No performance issue after all.
cljustin
Unfortunately, your AURA is defective and for it to be fixed, it'll need to be RMAed.
