Results 1 to 8 of 8
    ROG Junior Member Array
    Mar 2018
    3
    Unhappy How long does an RMA normally take?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,510
    As you have discovered it can vary greatly. If you are nearby a service center and they have parts in stock it might take less than a week. In your case it sounds like they do not have a needed part so it will take much longer. Your RMA is already not normal so "normal" time frames are already beyond relevance.
    I would just keep contacting the service center if you do not hear from them. Let them know you need it for work and anything they can do to speed up the process would be appreciated.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    RMAs do vary greatlly. Highly dependent on your proximity to a service center, their workload and parts availability. Ive seen things turn around in a week and Ive seen it take 6-8 weeks.
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,470
    We can say that normal RMA time is 15-20 days if you are in same country.
    Everything below 15 days is very cool.
    Excellent is when manufacturer discover problem as soon as possible to send information in store to replace you.
    But if you RMA in other country could be 20-25-30 days.
    EVGA do RMA very fast, and couldn't better than 20-22 days from Balkan to Germany.
    20 days is only 12-15 working days.
    ROG Guru: Orange Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    495
    I had to rma a board in France a couple of years ago took just over two weeks.
    Mar 2018
    3
    OK, I totally forgot to update on this post--sorry about this. So it took about two months. It arrived in a perfect condition and works quite well so far. I still have no idea why it broke down at the first place, and no one provided me with any sort of explanation, which I personally think the most frustrating.
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    301
    7,510
    Typically your RMA paperwork will include a basic description of what work was done, such as replacing a component. That doesn't always tell you why that component broke but at least it would give a general idea.
  8. #8
    ROG Member Array
    May 2018
    15
    Quote Originally Posted by xeromist View Post
    Mine just came back. About 5 business days for actual repairs and shipping, factor in 1-2 weeks depending on your location.
    Had to RMAs with that amount of time. Of course it also depends on your product and parts availability.
Tags for this Thread
