Results 1 to 2 of 2
Thread: Ram speed?
    ROG Enthusiast Array
    Jan 2012
    72
    Ram speed?
    At 4.8ghz how should i run my memory speed? my motherboard default the memory speed to 1333mhz my kit is CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866mhz?? please let me know.
    at 1333mhz which voltage would be batter at 1.50v or 1.65v?
    Dec 2011
    354
    25,742
    Javier set your ram at the xmp speed, make sure you set the timings manually in the BIOS, and the voltages too for the ram.
    At 1333MHz 1.5v would be fine.
