Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array Zammin PC Specs
    Zammin PC Specs
    MotherboardASUS ROG Maximus XI Formula
    ProcessorIntel 9900K (Conductonaut Applied)
    Memory (part number)G Skill 3200Mhz Trident Z RGB 32GB 3200Mhz CL16
    Graphics Card #1RTX 2080Ti FE
    MonitorAcer Predator XB271HU 165Hz
    Storage #1Samsung 970 EVO 2TB M.2 NVME SSD
    Storage #2Samsung 860 EVO 1TB SSD
    CPU CoolerEKWB Velocity RGB
    CaseLian Li PC-011 Dynamic
    Power SupplyCorsair RM1000i
    Keyboard Corsair K95 Platinum RGB
    Mouse Steel Series Rival 600
    Headset Astro A50 (Gen 2)
    Mouse Pad ASUS ROG Scabbard
    Headset/Speakers JBL LSR305 Mk II
    OS Windows 10 Pro 64bit
    Zammin's Avatar
    Mar 2018
    13
    233
    Strix 1080Ti - FanConnect 2 headers not working
    Hi everyone,
    I have an ROG Strix GTX1080Ti OC with a Phanteks water block fitted. The card has two "FanConnect 2" 4 pin fan headers on it as most strix cards do. I have just recently connected my two corsair ML140 PWM case fans to these headers to control through GPUTweak 2, however the GPUTweak software doesn't seem to detect them. I'm not seeing the "External Fan Speed" slider.
    The fans don't move, I've tried adjusting the regular fan speed slider and that doesn't affect it either, they just sit there not moving. When I start my PC they spin for a couple of seconds before turning off, and then I can't get them to move again.
    I have the latest version of GPUTweak 2. My system specs are under my username.
    If anyone could help me that would be great.
    Zammin PC Specs
    Zammin's Avatar
    Mar 2018
    13
    233
    Ah never mind, I figured it out. I had to add the external fan speed slider manually by clicking the icon on the top right.
