Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Member Array
    Dec 2015
    6
    Unhappy Wake on LAN not working from shutdown - Asus Deluxe Z170
    Hi guys
    I hope someone here can help me as I cannot find any recent topic which covers this.
    My problem is that since recently my PC wont boot from WOL when completely shutdown. If it's in standby then it will turn on from WOL packet but not when it is shutdown.
    For this reason I believe my issue is NOT Windows related, as Windows the issue exists only when the PC is completely turned off.
    It used to work fine, with Windows 10. I've not reinstalled the OS but I have installed all updates when released.
    I read about the Fast Boot causing the problem for Windows 10. But even after disabling this and rebooting a few times it still doesn't boot from WOL...
    https://support.microsoft.com/en-us/...and-windows-10
    When turned off I can see on my switch that the link is also down. Whereas when on standby I see the link is set to 10mbps so I know the NIC is off when the PC is shutdown.
    This leads me to think it's a bios issue.
    I found the EuP and PCIE Wake options. I experimented with different settings. Originally it was with EUP on (S4+S5 enabled) which from what I understand gives Windows the control to decide how to shut it down. I tried disabling that and setting PCIe wake enabled, but this hasn't resolved the issue.
    I know it CAN work as I used it a lot last year when on holiday, always from shutdown. I know the WOL packet is good because it boots out of standby.
    Please help! Why can't I get it to work from shutdown?
    Thanks
    Matt
    ROG Member Array
    Dec 2015
    6
    Red face
    WOL Fixed! For me was the Windows settings that fixed the type of shutdown somehow
    BIOS...
    Make screenshots
    Update BIOS
    Set settings how they were before update
    Set Advanced\APM Configuration\ErP Ready = DISABLED
    Set Advanced\APM Configuration\Power on by PCI-E = ENABLED
    WINDOWS...
    Open Powershell/CMD with ADMIN rights
    Run: REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Power" /V HiberbootEnabled /T REG_dWORD /D 0 /F
    Open device manager, find your NIC, open, drivers tab - Update driver. If nothing found, download directly from manufacturer website
    Once updated, reboot.
    After reboot, open NIC properties\Power Management tab:
    Tick all boxes - Allow computer to turn off device, allow to wake up, only allow magic packet.
    Open NIC properties\Advanced tab and (where available):
    Set Enable PME = ENABLED
    Set Energy Efficient Ethernet / Green etc = DISABLED
    Wake on Magic Packet = ENABLED
    Wake on Pattern Match = ENABLED
    Reboot, then after reboot shutdown.
    You should see the NIC stays enabled and you can boot from WOL packet. Bingo! Only took me 2 days.
    For me the solution was updating the drivers and disabling energy efficient mode. Crazy
    ROG Junior Member Array
    Jun 2014
    1
    This is the only article that helped me fix this! Thank you, thank you, thank you!
    EDIT: Also in case it helps anyone else battling this, I actually have an older motherboard: Asus P8B75-M/CSM.
    I recently switched from Windows 7 to Windows 10 (finally) and I believe that whatever default driver it installed (which didn't have the settings indicated above), as well as Fast Boot, disabled booting from S5. I don't really have benefit from WoL unless it boots from powered off, so it's good that these steps could fix it.
    ROG Member Array etacarinae PC Specs
    etacarinae PC Specs
    Laptop (Model)Razer Blade 15 Advanced / RZ09-02386E91
    MotherboardAsus ROG RVIEE / Bios 0070
    ProcessorIntel I9 10980xe
    Memory (part number)128GB G-Skill Trident Z RGB 3000MHz C14 / F4-3000C14Q2-128GTZR
    Graphics Card #1Evga RTX 3090 FTW3 Ultra
    Monitor3*Asus PG279Q
    Storage #1Intel Optane 905p 1.5TB HH
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Mouse Razer Mamba Elite
    Headset/Speakers KEF LS50
    OS Windows 10 Pro 64bit
    Network RouterASUS GT-AX11000
    etacarinae's Avatar
    Jan 2013
    20
    I feel terrible to necro an old thread, but holy crap. OP, did you ever know that you're my hero? Thank you, my man.
    Intel Core i9 10980XE | ASUS RAMPAGE VI EXTREME ENCORE | EVGA RTX 3090 FTW3 Ultra | 128GB G-Skill Trident Z RGB 3000MHz C14
    Intel Optane 905P 1.5TB HH PCIe | 2*4TB Samsung EVO 860 | 8TB Sabrent Rocket Q NVMe | 4*14TB Seagate Ironwolf Pro
    Corsair AX1600i | EK-AIO 360 D-RGB | Phanteks Enthoo Elite Satin Black | Windows 10 Pro 64-bit | 3*ASUS PG279Q
    Razer Mamba Elite | Razer Huntsman Elite / RAMA u80-A Lake
    ROG Member Array
    Sep 2013
    6
    Quote Originally Posted by etacarinae View Post
    I have to do the same thing.
    I have an ROG Strix X470 Gaming-F and had the same problem as OP, could wake from sleep but not from shut down. Installing the LAN drivers from Asus' page did not help.
    Only installing the drivers from Intel page (my LAN is an Intel I211-AT) worked because in their config page was an additional option to "Wake On Magic Packet from Power Off State". This was not in the normal network properties dialogue in Device manager.
    Thanks again to OP for putting me on the path to success.
    ROG Member Array
    Dec 2015
    6
    So happy my thread is helping many people.
    And for all of you who post a thank-you, I'm sure there are many more without a ROG account who this thread has helped.
    Good luck everyone and happy overclocking
  7. #7
    Oct 2013
    3
    Quote Originally Posted by GemeenAapje View Post
    Snip
    This worked!! Thank you
  8. #8
    ROG Member Array
    Aug 2012
    13
    Your a LEGEND!
    Your advice is still working many years later. I have Asus Z97i-PLUS.
    I was missing the "Energy Efficient Ethernet" option in the Windows Intel i218-V driver. Same issue you had fixed it for me.
    THANK YOU THANK YOU THANK YOU
  9. #9
    New ROGer Array
    Dec 2019
    1
    You made my day GemeenAapje :)
    Man, we're almost in 2021 and you saved my life
    Thanks a lot for this walkthrough, it worked perfectly with an Asus x570-e !
  10. #10
    New ROGer Array
    Nov 2020
    1
    Works on TUF Gaming Z490 Plus
    Thanks a lot, man!
    Your solution also works on the Asus TUF Gaming Z490 Plus, with newest drivers and all the settings you wrote. Once I set them, it worked instantly.
