Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 52 of 52
  1. #51
    ROG Enthusiast Array 28BeersLater PC Specs
    MotherboardRampage V Extreme
    Processori7-5930K
    Graphics Card #1ROG Strix Vega 64
    Sound CardBose External USB
    MonitorLG IPS235 x3
    Storage #1Kingston HyperX Predator 480GB
    Storage #2Corsair Neutron XT Series 960GB
    CPU CoolerEK RVE Monoblock
    CaseCorsair 900D
    Power SupplyCorsair AX1200
    Keyboard Logitech K800
    Mouse ROG Spatha
    Headset/Speakers Bose Companion 5
    OS Windows 10 Pro
    Network RouterROG Rapture GT-AC5300
    Jun 2016
    71
    Just to conform that the Dock and Mouse shouldn't be connected at the same time?
    In earlier versions it asked you to plug in the mouse for firmware updates!
    It doesn't make sense to have to unplug the dock to plug in the mouse (I regularly have to plug in due to a flat battery, as Syberon mentioned, it drains overnight, even with the PC off if I don't physically turn the mouse off. it never did that when it was on a very early firmware update (I was one that pre ordered).
    Is the battery issue ever going to be fixed? I too am now having wireless issues, as per my other thread. I have tried resetting and changing profiles, still no joy.
    Gotterdammerung: Rampage V Extreme | Intel I7-5930K | 32GB Corsair Dominator 2666 | EVGA GTX 980 SC x3
    Kingston HyperX Predator 480GB | Corsair Neutron XT 960GB | Corsair AX1200 | Corsair 900D | EK RVE Monoblock | EK 980 GTX Blocks
    GOOSE: STRIX Z390I Gaming | Intel i9-9900KF | 32GB Vengeance RGB 3200 | STRIX Vega 64 | Samsung 970 EVO Plus 1TB x2
    Corsair SF 750 | Phanteks Evolv Shift X | EK Z390I Monoblock | EK Strix Vega 64 GPU Block
  2. #52
    ROG Member Array Lunatic24_7 PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME
    ProcessorINTEL CORE i9 9900K 3.6GHz
    Memory (part number)T-FORCE NIGHTHAWK RGB 32GB
    Graphics Card #1Gigabyte Aorus 2080Ti Extreme
    MonitorACER PREDATOR Z35
    Storage #1SAMSUNG 970 EVO PLUS M.2 500GB
    Storage #2T-FORCE DELTA RGB SSD 500GB
    CPU CoolerASUS RYUJIN 360
    CasePHANTEKS EVOLV X
    Power SupplyASUS THOR 850W PLATINUM
    Keyboard RAZER DEATHSTALKER
    Mouse ASUS ROG SPATHA
    Headset ASUS ROG CENTURION 7.1
    Mouse Pad RAZER FIREFLY RGB
    OS WINDOWS 10 PRO x64
    Accessory #1 ASUS AURA CONTROLLER
    Accessory #2 NZXT INTERNAL USB HUB
    Accessory #3 CABLEMOD PRO MODMESH CUSTOM CABLING
    Lunatic24_7's Avatar
    Feb 2019
    9
    Asus Spartha Software
    Quote Originally Posted by 28BeersLater View Post
    Having built a new system last week with multiple ROG hardware parts (Maximus XI extreme, Ryujin 360, Thor 850W, Spatha, Aura Terminal, Centurion) I've found over the last few days that Asus' software is probably the worst I have ever used.
    Most of the hardware worked up until a week later, then I ended up having to reinstall the OS just to try and get Aura Sync to work again.
    Having re-installed the OS, it just made things worse as now Aura sync doesn't recognise three of the five original items it did before.
    added to the fact that I also can no longer use the spatha mouse wirelessly...its a constant battle keeping the ROG hardware working.
    I don't understand why Asus cannot release software that:
    1. Incorporates all their hardware
    2. Works with all their hardware
    3. Works...period!
    The fact that you have to uncouple the Spatha mouse from Aura Sync, before you can open up Asus Armoury is a testiment to how badly the software is designed and how incompatible the software suite is with each other.
    I've never had an issue with Asus' hardware...its only when you have to use their software that you realise how far behind companies such as Logitech Asus really are!
