Results 1 to 5 of 5
    New ROGer Array
    Mar 2018
    5
    Strix 503 Laptop's Desktop Freezing (started today)
    Hey all
    Today my laptop (ROG Strix 503) was turned on as one does and it did something strange that never happened before (2months old).
    So basically when i loaded windows and got to the desktop it was fine.
    So i proceeded to open up a folder which went well then another folder. From there i couldnt click anything in the folder whatsoever.
    I tried going to my task bar and once again couldnt highlight any of click anything over it. I could still move the cursor, alt tab between the windows and such and managed to move around sometimes via keyboard.
    But then it worked. Then quickly stoppes again.
    I reset the laptop and shut it down normally and still a nogo same thing.
    Because i have been frustrated through the evening with this i did a factory reset. SAME THING! I looked on the internet and did a system file checker which resulted in no errors.
    Im baffled. Dont want to take it to the tech guys just yet. Any ideas on what it might be?
    Thanks!
    PS. I even tried it in safe mode. Same thing.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,187
    Sounds like you have a hardware issue
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    New ROGer Array
    Mar 2018
    5
    Im going to have a tech look at it today.
    If he diagnoses the problem being hardware would it be covered by warrenty as its 2 months old?
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    111
    4,187
    Quote Originally Posted by Xenoclix View Post
    If he diagnoses the problem being hardware would it be covered by warranty as its 2 months old?
    Have you registered your notebook with Asus Support
    if so contact support, I would suggest you also PM cl-albert he is an Asus employee and is our Customer Loyalty rep in these forums? You haven't bothered to fill out your profile so don't know what country your in what notebook you have. There much different warranty's out there including a 3 month one for Referbs. Mine came with a 1 year and I purchased a 2-year warranty so your the only one that knows what warranty you have.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Super Moderator Array
    Jan 2016
    143
    Please update and install the new driver Version V22.20.16.4836
    http://dlcdnet.asus.com/pub/ASUS/Gam...494.1524965079
