Results 1 to 1 of 1
    New ROGer Array
    Nov 2015
    5
    Bios 3801 problems
    hello
    last week i decided to install AI Suite 3 version 10101 and upgrade it to DIP 1.05.14 to use full benefit of AI Suite other programs.
    Something happened, when i tried to start pc the splash screen of bios give me this message:
    - please enter setup to recover bios setting when Raid configuration was built
    Ensure to set Sata configuration to Raid mode
    Press F1 to run setup!
    after loading optimized defaults in bios and restarting, the message disappear.
    when shutting down the system for a while (5-10 minutes) and boot the system, the message appear
    i tried to flash back the bios to 3701 version, same problem
    i re installed windows 10 pro 64bit , same problem
    my spec's:
    asus rampage V extreme X99
    64 mb ram
    intel i7 5960X
    4 HD 4 tb each
