Results 1 to 8 of 8
    ROG Guru: White Belt Array
    May 2016
    114
    CPU temperature and usage on G752VY
    I have this G752VY with GTX 980M and 6700HQ for almost a year and a half now, I play a lot of overwatch and games in general, when I play overwatch the CPU and GPU usage seems to be unstable and the temperature of the CPU is around 85 Celsius in game and usage is around 40-60%, does that seems normal or something is wrong with my laptop. It feels different after my laptop went for some fan replacement due to a broken fan.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    yes that does seem high for only 40 -60 % usage are your fans kicking in? at 60C my fans would start kicking it at about 3800 RPM over 70C they kick up to 4200 RPM with the latest BIOS version 304 my fans idle around 1400 RPM
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    1,002
    I have a similar laptop but don't play that game. Go into Geforce Experience and click on that game, then check your custom settings. You might need to lower performance settings.
    Davemon50
    ROG Guru: Yellow Belt Array Spirery1 PC Specs
    Spirery1 PC Specs
    MotherboardAsus Maximus iv/gen3
    Processori73770k
    Memory (part number)20gig 1600mhz
    Graphics Card #1gtx 1070 airboss x4
    Sound CardSoundBlaster Z
    Monitorsamsung Gsync 144 27inch/PG285Q swift
    Storage #1Samsung Evo 850 120GB
    Storage #2Toshiba 2TB
    CPU CoolerAIO Nepton 120XL
    CaseAsus CG 8480 Republic of Gamers tytan
    Power Supplycorsair 550
    Keyboard Logitech G410/G910
    Mouse Logitech G300
    Headset Creative Fatalty
    Mouse Pad Ichill Inno3D
    OS Win 8.1/10 Laptop
    Network RouterTP-Link AC1900 Dual Band Touch Screen
    Accessory #1 EVGA SC 17 4K GTX 1070
    Accessory #2 soundblaster omni/T6300
    Accessory #3 gladius mouse
    Nov 2015
    125
    My g752vy has the 6820k and 980 8gb its just gone back for a second RMA only 7months if i stuck mine on extreme it would go 100c its why its gone back but only way i could game is fn/pgup that will turn fans on max to turn them off shut laptop down when they are on full all is well and 304 bios also . When i ring custom service they say 85 is hot send it back then letMeRepair saying 75-95 is fine so u could try for a rma or fans on full good looking laptop good spec for the money but QC is total crap will stick to building pcs would never get another gaming laptop after this .
    ROG Member Array
    Apr 2018
    7
    Quote Originally Posted by BL_11 View Post
    Running 68° on my i7 6700hq with all cores at 3.1. Undervolted - 0.125. I bet its just ****ty thermal paste. G501vw laptop
    May 2016
    114
    Quote Originally Posted by Spirery1 View Post
    Yea me too I am planning to build a new pc, buying a gaming laptop was not the best decision I've made.
  7. #7
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    I’m beginning to think the same*
  8. #8
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    This is true Gaming notebooks are great for working/ playing away from home but they can never compete with a gaming built desktop. there just isn't enough room in them. and no way to dissipate the heat generated by a full blown desktop. The heat sink on my Z97 board is all most as big and heavy as my G752VY What were you thinking.
    Just like any other major purchase, there are trade-off we suffer to have portability.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
