Results 1 to 4 of 4
Thread: 780s SLI Power Supply Query
04-16-2018 03:10 AM #1
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 19
Had a question about gtx 780s SLI and the power supply.
I just picked up an EVGA supernova P2 1000 watt PSU
which should be more than enough for this older build
I7 4790k @4.5, 1.210 v
16-gig ddr3 -2400
2-7200 hd
1 -200mm fan
4-120mm fan
and corsair h75 CLC.
I tried a seasonic 850watt PSU, the PCI-E cables were 6+2 and i used 4 separate cables for my 2 cards
The 6+2 connectors have 8 pins on both ends of the cables,but the side that hooks up the power supply has only 6 actual metal pins and not 8
I thought with allot of these higher wattage cards you want to use all 8 pins for enough power.
I do know they jumpered those 2 pins on the card side of the cable, am i being to picky or thats how make the PSU now.
Also when i up grade to single 1080 or even 1080 TI, will this EVGA p2 1000 be to much over kill?
04-16-2018 05:28 AM #2
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
If the PSU powers your system without issue the cables are fine, 780's are power hungry, over kill? what's that. If you already own the PSU why replace it when your power needs are lower, can't hurt anything
08-16-2019 01:19 AM #3
- Join Date
- Mar 2015
- Reputation
- 10
- Posts
- 19
Thanks Menthol, i know this late
08-16-2019 02:33 AM #4
- Join Date
- Feb 2019
- Reputation
- 129
- Posts
- 712
More than plenty. GPUs are under 120 watts each. 4970K OC to hell and back anotehr 140W all the rest not 100watts combined. pair of 1080ti cards about 500 watts for both.
So you have room to grow and the EVGA supernova is a decent PSU.
