04-16-2018 09:31 AM - last edited on 03-05-2024 07:11 PM by ROGBot
04-16-2018 09:43 AM
04-16-2018 11:22 AM
04-18-2018 02:40 PM
04-18-2018 02:52 PM
04-18-2018 03:08 PM
Wischmaster wrote:
The Asus support guy told me I needed a PCIe 3.0x4, according to my serial number. That's what my SM951 is.
Wischmaster wrote:
Wouldn't a SATA3 M.2 SSD require a B&M key connector type? While mine is an M type on my motherboard. I have a picture of it attached to my first post. Unless SATA3 doesn't need all the pins connected to work?
04-18-2018 04:55 PM
04-23-2018 10:18 AM
01-10-2021 08:22 PM
Wischmaster wrote:
Alright, since I couldn't find any information on M.2 slot compatibility in regards to if a "B+M" key will work in a "M" key slot even though some pins have no contact on the board side, I decided to take the plunge and order yet another M.2 SSD. This would be my third.
I ordered the above shown Samsung 860 EVO 250GB M.2 SATA SSD.
When I originally contacted support they said I needed a PCIe 3.0x4 AHCI compatible M.2 SSD, this was incorrect because I could never get the drive to interact. After cl-Albert graciously helped me, he did some serial number research and found that I indeed needed a SATA M.2 SSD.
I installed the drive today and when I went to Disk Management, I was pleasantly met with a window stating that I needed to configure the drive for Windows to use it. After that, it's shown as an unallocated drive and ready to use. Now to clear everything, make the M.2 my boot drive and reinstall everything.
I've attached an image of the keys to show what I meant by pins not having contact as well as an installed picture. I do this because I notice a huge lack of pictures with most things on this forum, they can be very informative to someone else having this same issue. Which apparently is quite a few, based on my weeks of Googling 😮
Mark this one as solved!
