Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    New ROGer Array
    Apr 2018
    3
    Maximus X Hero with Trident Z 4133 MHz problems!
    Hello all!
    I am a new user in this forum, where I hope to find help for my problem.
    In the last days I decided to improve my computer, where I changed the motherboard, processor and memory.
    The choice fell on the Asus ROG motherboard Maximus X Hero (without Wi-Fi), the Intel Core i7-8700k processor (has been delid) and the G-Skill Trident Z RGB 16GB memory with clock speed of 4133 MHz (the exact model is: F4-4133C19D-16GTZR ). It is a used set from the first owner who purchased the above-mentioned components two months ago (everything has a shop warranty, except for the processor that was delided - he used liquid metal - Thermal Grizzly Conductonaut, and the processor was already installed in the socket).
    Of course, when transporting components, I removed RAM from the sockets, because of security, but once I've installed them back home, the BIOS resets to the initial settings.
    Go to the particulars when I want to set the XMP profile for memory (2133 MHz by default), the computer is reset, where next on the POST code reader (Q-Code) there is b1. Yes, code b1, no 61. After this code, the computer resets again 3 times and then pops up after starting the computer that a POST error has occurred and to go to the BIOS settings. When I'm in them, I see that clocking has not occurred correctly and everything has returned to factory settings. I have also suggested an overclocking guide from Der8auer, but this does not give positive results. I also changed the memory of A2-B2 slots. Result? Negative.
    I also tried to gradually change the DRAM Voltage between 1.3500v and 1.4000v, and the VCCIO / System Agent Voltage CPU between 1.31v -1.33v // to 2.0v and 2.375v and from the lowest half of 1.15v. but it ended with the same code error.
    BIOS version, under which I performed OC data, is 1003 and 1101, but I did not attempt to 0802.
    Other components are:
    Air Cooling: Cooler Master T4
    GPU: Asus Rog GTX1070 Advanced OC 8GB
    PSU: Corsair CX750M 750W Green edition (NOT GRAY).
    SSD: Crucial MX200 250GB
    HDD: WD Blue 1TB
    Case: NZXT s340 Window Edition
    If I add something to myself, when I chose the day before, the TPU option in the BIOS (TPU 1) alone raised the memory timing to 3733 MHz, but I do not know on what values ​​the other values ​​oscillated + the CPU clock was also increased.
    Thank you all for help, and I apologize for my English.
    Regards!
    ROG Guru: Green Belt Array Heini PC Specs
    Heini PC Specs
    MotherboardAsus SABERTOOTH Z170 MARK 1
    Processori7-6700K
    Memory (part number)G.SKILL TridentZ (2 x 16GB) F4-3000C14D
    Graphics Card #1Evga 2080Ti XC Ultra
    Sound CardAsus Essence STX II
    MonitorASUS MG279Q
    Storage #1Samsung 950 Pro 512GB
    CPU CoolerNoctua NH-D15
    CaseCooler Master HAF XB EVO
    Power SupplyEVGA SuperNOVA G3 1000W
    Keyboard Ducky Shine 6 (Brown Cherry MX)
    Mouse Secret (Ducky)
    Headset Sennheiser HD 580
    Mouse Pad EVGA TORQ
    Headset/Speakers Logitech Z906
    OS Win10 Pro 64
    Heini's Avatar
    Nov 2013
    50
    600
    Quote Originally Posted by Guardas View Post
    I'd bet that ASUS nor G-Skill will honor a warranty on second hand components and obviously Intel won't. I hope you bought them from someone who can be trusted to help. Sorry I can't help with your problem but I have to ask... "Why buy so new components, used?" If it didn't work for them that would be a red flag to most of us.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Are you just having trouble running memory at 4133 Mhz or are you having other issue's
    Does the system work when memory is left at default speed?
    Have you checked the CPU socket for bent or damaged pins?
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Hello all!
    HDD: WD Blue 1TB
    Regards!
    Error code bi is a memory related error..............It may be something as simple as memory training....are u giving the system enough time to cycle / learn ? ...Have u tried disabling the memory training ??
    Have u cleared the CMOS to start from scratch?? (As system was from a previous owner with ???? settings)
    Have u tried setting the memory at 4133 MHZ (auto) instead of XMP ??
    Have u tried booting the system with just one stick with 4133 MHZ in XMP then add the 2nd stick afterwards.
    Has the ram been inserted firmly within the ram slots??
    If none of the above works.....as mentioned by Menthol....if very well may come down to bent pin in the socket... a bad memory controller within the cpu...or the ram itself is at fault (which is hard to believe that both sticks have errors)
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
    New ROGer Array
    Apr 2018
    3
    @Heini, thank you for your answer. I know, it seems ridiculous to buy "used" parts from another person, but they are new enough to be purchased 2 months ago, and have all the warranty documents, so I can always say that they were bought by my brother or cousin. Also the fact is that when I received them personally, all the components were still in the computer and worked properly with the XMP 4133 MHz profile, and the processor was turned up to 5 GHz.
    @Menthol, thank you too for your answer. Yes, I have a problem with running memory in XMP - 4133 MHz mode at latencies 19-19-19-39. When they are at 2133 MHz factory settings, then everything works normally, and the system normally works, there are no problems. And no, I did not check if the pins in the socket are bent, because the processor was not pulled out of the slot while traveling and at home during installation.
    @Phillyflyer, Thank you for your answer!
    No, I did not turn off the memory training in BIOS.
    Yes, I reset the CMOS to start from scratch.
    Yes, I set the XMP memory in AUTO mode (4133 MHz), but then the error code b1 begins.
    No, I did not try to run the system on only one stick with no profile and with an XMP profile.
    Yes, they have been firmly inserted into the memory slots.
    Well, I'm still pushing the processor out of the CPU socket to check if the pins in the socket are not bent, if none of the tips are helpful.
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Checking the socket will if nothing else give peace of mind that the socket is not a problem.
    Was there a preset in the bios for the former 4133Mhz settings?
    Try setting XMP, manually enter 1.4 volts on memory and VCCIO, VCCSA from chart below
Name:	IO SA Volts.JPG
  7. #7
    New ROGer Array
    Apr 2018
    3
    @Menthol, Tweak mode leave it on AUTO or put on mode 1 ?
  8. #8
    ROG Member Array ssuteck PC Specs
    ssuteck PC Specs
    MotherboardAsus Maximus X Hero (WI-FI) AC
    Processori7 8700K
    Memory (part number)F4-3466C16D-16GVK
    Graphics Card #11080 Ti Hydro Copper
    Monitor3x BenQ 27"
    Storage #1Samsung 950Pro 512GB
    Storage #2OCZ Vortex 4
    CPU CoolerHeatKiller IV full copper waterblock
    CaseDefine S
    Power SupplySilverstone 1500W Modular
    Keyboard Mad Catz Strike 7 Modular Gaming
    Mouse Multiples and spares cuz I'm a thrower during games lol
    Headset/Speakers Samsung Surround system 7.1
    OS duh
    Apr 2018
    6
    Thumbs up Asus z370
    You're going to have to overclock it the old fashion way. Voltage and timing tweaks over and over until you get what you can. Asus has informed me that unless there is an XMP at the end of the memory name in the QVL for your motherboard - ex. CMD16GX4M2B3000C15(Ver5.30)(XMP). Then the memory will not work in XMP mode. Not to say you can't overclock it, just that using the XMP mode is useless. XMP mode for the asus Z370 motherboards only goes up to 3000Mhz for everyone that I checked. All other motherboard manufactures that I checked, (gigabyte, MSI, asrock), have memory in their QVL's that have xmp enabled for the higher clock speeds. Most go up to 3600 and 3733Mhz while some go all the way to 4133Mhz. But not ASUS. I think they dropped the ball on this chipset.
    So turn it to manual, set it to the 4133 Mhz, set your voltage to ~1.40 and the timings to 19-19-19-39 and start tweaking voltages and modes from there. Use the advice these guys are giving you. It will help you get where you want or at least closer.
  9. #9
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Try auto, mode, 1 and mode 2
  10. #10
    ROG Member Array
    Dec 2017
    I have the same board (but Wi-Fi version instead) and the same RAM as well.
    Updated to the latest BIOS that was posted on the forum today (1301).
    Followed the suggestions above and instead of using XMP (since the QVL doesn't show XMP listed for this particular RAM, or any of the G-Skill RAM for that matter) I set AI Overclock Tuner to manual and set the RAM frequency and timings manually (DDR4-4133, 19-19-19-39 2T). I started at 1.35 RAM voltage and was not able to boot. But then I set Tweak Mode to Mode 1 (it was on Auto by default) and booted successfully. However, it was not very stable (programs crashing, BSOD, etc). Upped the voltage to 1.40 and still got a BSOD eventually. Upped it to 1.45 and now things seem to have stabilized.
    Is 1.45 a safe value to use 24/7?
    I didn't mess around with CPU VCCIO voltage or CPU System Agent voltage at all (they are Auto by default). Should I perhaps experiment with those (maybe they would allow me to lower the RAM voltage a tad?) or should I just keep running 1.45 if it works fine and leave VCCIO and SA voltage on Auto?
