Results 1 to 1 of 1
    ROG Guru: Orange Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    474
    Help needed setting rad fans on R6e
    I have installed a full cover block on r6e with D5 pump and 420 rad (3 x 140 fans Pwm) with the fans on a splitter and plugged to cpu fan header.
    I also have full cover block on Titan V, 420 rad and D5 pump ( 3 x 140 Vardar fans Pwm) fans on splitter and plugged to fan header 2.
    My problem is cpu fans stay constant but when cpu temps rise, the gpu fans ramp up and run at max ( ear defenders anyone! Lol).
    Plus the gpu pump led cable is plugged to the 12v header but not working?
    Have I made the right header connections or is there more I should be setting up?
    Benching, cpu ends up going into the 90s, because fans not increasing and the gpu never above 31deg ( but then it wouldn’t with fans full blast)*
