Results 1 to 10 of 28
04-19-2018 02:26 AM #1
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 21
When are you guys going to fix Adaptive Mode OC for Maximus X Hero?
I'm forced to use manual mode, it has a precise and solid voltage, example: I set 1.310v in BIOS with LLC 5 and my idle voltage is 1.312v and full load is 1.280v, a nice vdroop as it should be, but if I used adaptive mode, my voltage fluctuates a lot, just by opening a browser tab it jumps to 1.375v from 1.312 and the load is inconstant, keep changing from 1.265v to 1.360v, I can mitigate that using an AVX offset but it is still broken and nothing like manual mode, I heard that there are other boards that are doing fine using adaptive mode.
04-19-2018 08:10 AM #2
Which UEFI version and how are you setting Adaptive voltage? Might want to share screenshots of the BIOS settings.
04-19-2018 02:59 PM #3
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 21
Using 1101, also a lot of people have this problem (I asked one time in OCnet), I just set additional turbo voltage to 1.310v just like for manual mode and leave the offset on auto, it doesn't matter if I apply negative or positive offset, the voltage fluctuates the same under load/idle. Also I tested with SVID to Best-Case Scenario and set AC/DC Loadline to 0.01 and no changes at all.
04-19-2018 03:03 PM #4
04-19-2018 04:56 PM #5
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 21
Well, I set cache to 48x (min and max), Ring Down Bus AUTO and just changed the short and long power (something like that, it's in the same screen of AC/DC Loadline) to 4095 or something close to that, the maximum value, also set 255.50 for another thing related to cache I think, just disabling power save features and assuring I will have always the maximum performance. To test the voltage fluctuation I've disabled C-States, SpeedStep and SpeedShift and left only Turbo Boost enabled, and also set Windows power plan to 100% for minimum state while using all of this with adaptive mode, so I could monitor the minimum and maximum voltage values with HWInfo64 while browsing, idleing and full load stressing.
04-20-2018 12:36 AM #6
What happens when you leave the cache ratio and all related settings on auto? Cache voltage and vcore is shared, so changes to the cache settings can affect the requested voltage. You shouldn't need to set all these power settings manually, either. Start at defaults (clear cmos), only set vcore and the cpu ratio (you can try per core and sync all cores), then check voltages.
04-20-2018 03:13 AM #7
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 21
04-20-2018 03:22 AM #8
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 21
One interesting thing I noticed, I tried with SVID Best-Case Scenario and AC/DC 0.01 and for 4.5Ghz core and 45x min and max cache with the same 1.310v voltage it was solid 1.312v and 1.296v for loading/stress, didn't noticed spikes over 1.312v, but then I tried 5.0Ghz and the same 45x for cache, now I had voltage jumps to 1.360v, 1.344v just by opening Google Chrome tabs, so seems like a certain frequency using THE SAME voltage varies when using adaptive mode.
04-20-2018 07:48 AM #9
bass junkie xl PC Specs Motherboard Asus Rog XI Code Z-390 -Bios -1502 Processor i9-9900-Ks @ 5.0/4.7 Cache @ 1.23v Memory (part number) 32 GB ( 8 GB x 4 ) Team Group X @ 4133 mhz cl-17-17-17-34 @ 1.45v / vccio = 1.25v/ vcssa = 1.25 v Graphics Card #1 Msi Gtx 1080 TI FE + Kraken G12 360mm Aio @ 2000 mhz @ 1.062v Curve Sound Card Motherboard Realtec , Driver 87.46 Monitor Asus PG279Q , 27 inch 165 HZ , 1440p G-Sync Storage #1 Samsung 970 evo 1 TB x 2 m.2 nvme ssd Storage #2 Samsung 970 evo + 500 GB (OS ) m.2 nvme ssd CPU Cooler Deep Cool Gamermaxx 360mm v2 / Kraken G12 s36 360mm Case Thermaltake View 71 full Glass Power Supply Evga 1000w Platnuim Keyboard Corsair K95 Platnuim RGB Mouse Corsair Night Sword RGB Headset Razer Kraken 7.1 chroma Mouse Pad Asus Sheeth Large Headset/Speakers Logitech Z-5500 THX 5.1 OS Windows 10-1909 x64 Pro
- Join Date
- Oct 2017
- Reputation
- 28
- Posts
- 339
yepp i noticed the same thing and buged me i needed 1,36v for 5 ghz and i would get spikes up to 1.392v .... on battlefield 1 ia/dc 0.01 loadline = 6
went back to manual vcore 1.36v with speed step enabled ( cpu drops down to 0.800 mhz just not the voltege ) - a lil power saving lol .
i wish it would not go past your set voltege in 0.016v steps like if it jumped to 1.372v that wouldnt be to bad but she jumps 1 - 3 svid stacks 0.016 v x 3 when running games
04-20-2018 08:01 AM #10
Just a few things:
1) For your reference, if you set SVID to best case, you don't need to set the AC/DC loadlines to 0.01. That's because 'best case' sets 0.01 for you.
2) So, ratios under 50X are okay, or is it just 45X? Let me know, I'll replicate and see what needs sorting.
