Results 1 to 2 of 2
    ROG Junior Member Array
    Aug 2016
    1
    ROG STRIX Z270F fan headers and Magnetic Levitation fans?
    So, I've been thinking about getting Corsairs ML120PRO RGB Magnetic Levitation bearing fans but then I came across that they seem to require constant 12V to work properly and not break.
    I tried looking for information regarding the PWM fan headers on the motherboard if they're suitable for this (as in if they are true PWM and capable of supplying that constant 12V instead of being 5v ones) , but only port on manual that has some sort of specification regarding this is CPU_FAN (page 1-16). What about all the other ports?
    Any help would be appreciated. Really not looking forward to spending good amount of money on fans only to find out I'm out of luck with my motherboard.
    http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/STRIX_Z270F_GAMING/E12193_STRIX_Z270F_GAMING_UM_V2_WEB.pdf
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,125
    OK, so out of the gate let me just say, you're going to be fine.
    These are PWM fans (that's based on the model number you listed and my visit to the Corsair website page, so just make sure it actually says PWM before you buy them). PWM fans are going to be controlled by a 4-pin header/connector, and that's the key indicator for you. One of the four connecting wires is a 12V connection, and the modulating control signal is generated on another one of the four wires. So it still gets the required voltage, but it just changes the fan operation through modulation of the control waveform. Those fans have an operating voltage range from 10.8 to 13.2 volts.
    If you are buying 3-pin fans they can have the ability to modulate under certain connection configurations, but they would actually modulate the voltage to change the speed of the fans, so just make sure you are not using a 3-pin header or a 3-pin fan. Must be 4-pin fan connected on a PWM 4-pin header. In reality it doesn't have to modulate, but why use PWM fan if you didn't want to modulate?
    We use maglev chillers now pretty commonly (trains now for a while too), and they are much quieter. I'd love to hear your feedback on how quiet they operate when you install them. For chillers, the bearings are powered at startup and stop, so the motor/shaft coasts to a stop while the bearings are still powered. They also have backups but I doubt these little computer fans do. The other thing you should see is reduced power consumption - I'm not sure if you monitor your systems amp draw, but there should be a slight impact on your fan power use (reduced with maglev).
    Davemon50
Tags for this Thread
