Results 1 to 10 of 16
Thread: Auto shutdown
04-25-2018 11:51 PM #1
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 4
C7H Auto shutdown
I have NO idea what is going on. My newly built ryzen platform 2700x, c7h will automagically shut down during extended idle. It won't be able to power up by using the power button.. My razer mouse still have led.. Mobo start button have led.. No q code. I have to manually switch off and on my psu then I'm able to power up normally.. Anyone know what's going on?
Im on the latest beta bios.. It happens even on the last official bios.Last edited by infatality; 04-26-2018 at 01:06 AM.
04-26-2018 12:00 AM #2
haihane PC Specs Motherboard Crosshair V Formula Z Processor AMD FX 8350 Memory (part number) Gskill F3-2400C10-8GTX Graphics Card #1 ASUS HD 6950 Storage #1 WD Velociraptor 1TB Storage #2 Corsair Neutron GTX 120GB SSD CPU Cooler Cooler Master Seidon 120XL Case Cooler Master Silencio 650 Power Supply Corsair HX850 Keyboard Corsair K70 RGB Mouse Logitech G500 OS Windows 7 X64 Network Router Linksys E2500
- Join Date
- Jul 2013
- Reputation
- 106
- Posts
- 616
uh,
Windows Power options?no siggy, saw stuff that made me sad.
04-26-2018 12:27 AM #3
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 3
Are all the bios settings on their default value?
Can be caused by an unstable overclocking or a faulty hardware.Last edited by nimer; 04-26-2018 at 12:30 AM.
04-26-2018 12:55 AM #4
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 4
04-26-2018 12:56 AM #5
- Join Date
- Apr 2018
- Reputation
- 10
- Posts
- 4
04-26-2018 03:26 PM #6
lightknightrr PC Specs Motherboard Asus Crosshair VI Hero WiFi Processor AMD Ryzen-7 1800X Memory (part number) F4-3200C14D-32GTZ Graphics Card #1 Radeon Vega Frontier Edition Sound Card HT Omega eClaro Monitor Samsung 4K Storage #1 Samsung NVMe SSD 960 PRO 1TB Storage #2 Crucial MX200 1TB SSD CPU Cooler Corsair H115i Case Thermaltake Chaser Mk-1 (Modified) Power Supply Thermaltake Toughpower DPS G RGB 1500W Titanium Keyboard Corsair K95 RGB PLATINUM Mouse Corsair Scimitar Pro RGB Mouse Pad Corsair Gaming MM600 Dual Sided Aluminum Gaming Mouse Pad OS Windows 10 Pro 64-bit OEM Network Router Cisco ASA 5516-X Accessory #1 Firewire Expansion Card Accessory #2 Black Magic Intensity Pro 4K Accessory #3 Mailiya USB 3.0 5-Port Expansion Card
- Join Date
- Jan 2017
- Reputation
- 10
- Posts
- 152
I think, like with the CH6, there's a chip either getting too hot, or receiving too many bad commands, that's resulting in this nonsense. I say this, as my CH6 Wifi will run for days without issue, then suddenly die; machine needs to be fully switched off, and then switched on before it will work again, and this is with top of the line components. Perhaps it's the VRM? But I want a program or logger or something to find out the problem definitely before randomly swapping even more components at this point...Event Viewer shows nothing worthwhile.
04-28-2018 10:10 PM #7
- Join Date
- Jul 2012
- Reputation
- 10
- Posts
- 222
See this post: https://rog.asus.com/forum/showthrea...-anyone-else#4
You should check to see if this maybe causing the problem you are seeing.
04-29-2018 02:00 AM #8
aeonconcepts PC Specs Motherboard Asus Crosshair VII Hero Processor Ryzen 2700X Memory (part number) F4-3200C14D-32GFX Graphics Card #1 GTX 1080 ti Ekwb Water Block Monitor LG34UM95 Storage #1 Samsung EVO 960 M.2 CPU Cooler Ekwb Monoblock Case Corsair Air 540 Power Supply Corsair Ax860i Keyboard CrapSeries M800 Mouse CrapSeries Rival 310 Headset CrapSeries Siberia OS Win 10 X64
- Join Date
- Dec 2016
- Reputation
- 10
- Posts
- 28
Elmor confirmed that Corsairlink software will also cause random shutdowns: if you have it installed.
05-01-2018 03:00 PM #9
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 4
05-01-2018 03:12 PM #10
- Join Date
- Dec 2016
- Reputation
- 10
- Posts
- 28
Corsair link and nzxt software have been confirmed on overclock.net more info on the ch7 thread on that site
