Results 1 to 7 of 7
    ROG Member Array surfer96's Avatar
    Feb 2017
    14
    G752VT Fans going at 100% for unknown reason (SOLVED)
    I start up my G752VT running Windows 10 Home, open Edge and browse Amazon site for around 10 minutes when suddenly the fans start blazing at 100%, but CPU temperature is only 32%.
    I installed Notebook Fan Control (latest beta with profile for G752VT), but it doesn't seem to have the fans under control at all.
    A simple Windows restart doesn't slow down the fans.
    The only way to turn them of is shutting down the pc completely and start it up again.
    Any suggestions?
    Super Moderator Array
    Jan 2013
    99
    2,135
    Not sure if it can help, but check the thread below if you haven't seen it.
    Hope it can help.
    https://rog.asus.com/forum/showthrea...-max-fan-speed
    ROG Guru: Yellow Belt Array Spirery1 PC Specs
    Spirery1 PC Specs
    MotherboardAsus Maximus iv/gen3
    Processori73770k
    Memory (part number)20gig 1600mhz
    Graphics Card #1gtx 1070 airboss x4
    Sound CardSoundBlaster Z
    Monitorsamsung Gsync 144 27inch/PG285Q swift
    Storage #1Samsung Evo 850 120GB
    Storage #2Toshiba 2TB
    CPU CoolerAIO Nepton 120XL
    CaseAsus CG 8480 Republic of Gamers tytan
    Power Supplycorsair 550
    Keyboard Logitech G410/G910
    Mouse Logitech G300
    Headset Creative Fatalty
    Mouse Pad Ichill Inno3D
    OS Win 8.1/10 Laptop
    Network RouterTP-Link AC1900 Dual Band Touch Screen
    Accessory #1 EVGA SC 17 4K GTX 1070
    Accessory #2 soundblaster omni/T6300
    Accessory #3 gladius mouse
    Nov 2015
    125
    If u have a usb keyboard scroll lock sticks fans on full or pg/up plus fn just watch what your pressing.
    Feb 2017
    14
    Quote Originally Posted by Spirery1 View Post
    I tried pressing the scroll lock key and can confirm that also for the G752VT the fans start blowing at maximum speed after a couple of seconds.
    Since I've just started using a new USB keyboard where the scroll lock key is positioned quite a bit lower than the previous one, so I guess I may accidentally press it when looking for the home key. Thanks for clearing this up for me.
    Anyway it is very annoying that there is no way to shut down/regulate the fans manually though. If anyone has a solution, please reply here. Thanks!
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    Yeah I use a g410 on my G752VY I just have scroll lock in red so I don’t press it like a don’t press button lol
    Feb 2017
    14
    I just installed - https://keytweak.informer.com/ - and used it to disable the scroll lock key. All seems to be working fine for now.
  7. #7
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    Oh many thanks will have to try it when my laptop comes back from repair next month waiting on a part to come from ASUS us 15/5 lol
Tags for this Thread
