04-27-2018 10:21 AM - last edited on 03-06-2024 08:51 PM by ROGBot
04-27-2018 01:38 PM
04-30-2018 06:26 AM
xeromist wrote:
I was starting to speculate but I don't have this chipset so hopefully you can get some experienced replies from the the IRST forums. I will say that the graying out seems like a documentation failure on Intel's part. If there is a limit (and it sounds like there is) it should be documented.
But on a tangent hopefully someone has cautioned you against 8x6TB drives in RAID 5. Rebuilds are hard on an array and 42TB is going to take a very very long time to rebuild. The rebuild could kill a 2nd drive and you will lose everything. I wouldn't trust anything you can't afford to lose to such an array. For 8 drives you really need RAID 10 or RAID 6 to feel reasonably safe. Maybe you already know but I just wanted to make sure.
05-01-2018 11:58 AM
AviatorDuck wrote:
I use the RAID5 array for performance and shear single volume size....not data integrity. I understand the rebuild time issues with an array that large...In the past I have worked for EMC! 🙂 And that brings me to the reason I run such a large array....along with being a gamer....I will use this computer as a "mini lab" to supplement my development servers....Work Machine Mon-Fri 9am-5pm....gaming machine the rest of the time! 🙂 So this array will be filled up with....and run.....lots of virtual machines that I use for work. It will also serve as the local backup for my development servers.
I have also found (and maybe this has changed over the years) that these consumer level RAID controllers don't do a very good job defragmenting themselves so over time they get a bit slower than when they were first built and loaded. I typically rebuild an array once a year or so to keep it fresh and running at top performance.
As for data loss...I use my development servers as a local backup....and vice versa (thus reasons for wanting such a large array) then that gets backed up to the cloud so in the case of a drive failure, or my house burns to the ground.... I have choices of a local or cloud restore point....(virtual machines....because of their file sizes....tend to restore quickly. Unlike a use case where one might have TB's of photos, mp3's and such that would take longer to restore from backup.)
As for the IRST forums, they have not been helpful as of yet. But your theory of max limits does seem very plausible. I will update my post over there to see if I can get the folks over there to provide some max limit data. Thanks for the tip! 🙂
AviatorDuck
05-01-2018 01:26 PM
05-01-2018 04:12 PM
AviatorDuck wrote:
Intel came through with information and answers! The limit for a single drive array with IRST is 6 drives in a single array! 🙂 Even though their PCH controller docs state that the only limit is the number of SATA ports on the PCH controller! So that is why I could create 2 four drive arrays but not a single 8 drive array! I have provided the link below for any that would like to see all the possible configurations with IRST and various controllers!
https://communities.intel.com/thread/124926
Thanks to all for your valued assistance! 🙂
Cheers,
AviatorDuck
05-02-2018 11:03 AM
CharlieH wrote:
What about the IRSTE that's what I am using and it use to work with AHCI.
05-08-2018 10:48 PM
AviatorDuck wrote:
If I follow your question properly CharlieH....it is not a software/version/driver issue, but rather a controller limitation. But maybe I have missed something...do you have info on IRSTe that says it can do 8 drive arrays on x299? If so, please share so I can review it! 🙂
04-27-2018 03:12 PM
04-29-2018 02:16 AM
