Another Air cooled i7 8700K build
edisuleiman
Hi
here is my Asus Z370 ROG X formula build..I have plans for custom watercooling later this year but at the moment I kinda enjoy and like this simple build. Have to modify my Lian Li PC-08 case and instead of using Lian li's own vertical GPU kit, I opted for Cooler master kit (Which is way cheaper). Rear and top fans are set to intake with a 3rd party built in dust filter for the rear. This setup is the best for me in terms of airflow and cpu/GPU temps. I also made a separate D.I.Y system monitoring 5" LCD .What do you guys think?
Specs:
Intel Core i7-8700K )C @ 4.9MHz
ASUS ROG Maximus X Formula
Noctua NH-D15
Noctua NF-P12 Fan x 3
Thermaltake Riing Plus 12 x 3
Corsair Dominator Platinum x2 16GB DDR4-3200
Samsung 960 EVO 500gb M.2
Seagate BarraCuda Pro 3TB 7200RPM x 1
WD Black 2TB 7200RPM x 1
ASUS ROG Strix GTX 1080ti
ASUS PG348Q
Corsair H750i PSU
7359173592
7359373594
5 REPLIES 5
EvolutionX
looks awesome gj
davemon50
Level 11
All I can say is "wow that is certainly bright" ! Looks nice Edi.
Davemon50
Menthol
Level 14
Sweet, what case model #
I love the 2-compartment design with great visibility through the front and side in the Lian Li PC-08. PC-09 is more ROG though 😛
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
yes it is a Lian Li PC-08. This case is nice in terms of form but have mediocre airflow performance. I had to modify the case and install vertical GPU bracket to obtain a decent GPU cooling..At least now at full load max temp for my GTX 1080Ti GPU is 80c @ 1949MHz
