Hello,
G750JZ’s thermal module is designed for under 3.4 GHz. So if you would like to do overclocking to 4.0 GHz, it may trigger over temperature protection and your laptop will shut down. As a result, we would not suggest you to do extra overclocking to your G750JZ.
Thanks.
