G750 JM CPU Fan Noise, where to Buy a New Fan?
Frostbite7274
I'm using a Asus G750JM for the last 3 and a half years and about 1 month ago the CPU fan started to make buzzing noises. It starts randomly and it only stops if i shut down the laptop then restart, then it stops for about 4-5 hours and starts again. I cleaned the fan with compressed air twice. Every time the sound stops for about 3-4 days then it starts again.
Example: https://youtu.be/_pTCOJ7cJbk
Do i have to disassemble the fan and clean every part or buy a new one?
If i need to buy a new one can you recommend some sites where i can do that?
4 REPLIES 4
Clintlgm
Level 14
Ebay
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
Joanne1
Hi
you can visit ASUS Romania Website and contact the local service via email/call/online chat,and they will find the way to solve your problem or tell you where to buy a new fan nearby.
Website: https://www.asus.com/ro/support/
Hope it will help you 🙂
EfK89
You can try cleaning the fan and using sewing oil in the bearings, there are a lot of youtube vids about that.
If that doesnt work this site sells a lot of parts : https://www.asus-accessories.com/
davemon50
Level 11
If you have an electric razor, it probably came with a vial of oil for the bearings to keep them lubed. I use that for such things too because it's on hand. Try it (sparingly, like 1 or 2 drops at most) if you have some.
Davemon50
