GL502VS-DB71 GPU fan problem
Poolequery
I've been having a problem with my GPUs fan, even on idle it spins like I'm playing a high load game. My GPU temp is about 40-50 on idle, and I've tried using the 3D setting trick and the reset to default setting trick on BIOS. Third party software doesn't seem to work either to control the fans, they must be locked. It seems to be an issue on the FCU since I've never encountered this problem on the Anniversary update. Problem after problem with this laptop, huge disappointment..
0 REPLIES 0
