05-05-2018 10:14 AM - last edited on 03-06-2024 08:49 PM by ROGBot
05-05-2018 02:08 PM
05-05-2018 02:40 PM
brkkab123 wrote:
Apparently nVidia's last previos driver had a issue on all GTX 1060's and they released a new driver 397.31. Get it here and see if your issue is fixed.
https://www.geforce.com/drivers
05-05-2018 02:44 PM
arronjgreen wrote:
It looks like that is the version I have installed unfortunately - I'll try to reinstall it - it seems like it is the video card - but it is brand new from the store so I just assume it was a misconfiguration in the bios - but now that I am running everything well below capability, something has to give.
Will report back if updating the driver again helps.
05-05-2018 03:11 PM
05-05-2018 07:25 PM
05-06-2018 07:27 PM
05-11-2018 03:19 AM
05-12-2018 06:53 PM
Flexerl wrote:
You can check the spec of each DIMM with Thaiphoon (manufacturer, ranks and the like), should cover all your chip related questions.
