Results 1 to 1 of 1
    ROG Enthusiast Array Honami PC Specs
    Honami PC Specs
    MotherboardASUS Rampage V Edition 10
    ProcessorCore i7-6900K @ 4.0 Ghz
    Memory (part number)64 GB Kingston HyperX Predator DDR4 3000Mhz (4X16)
    Graphics Card #1Gigabyte GTX 1080 G1 Gaming
    Sound CardASUS Strix Raid Pro
    MonitorDELL U2715H
    Storage #1Samsung 950 Pro 512 GB
    Storage #2Samsung 850 Pro 512GBX2 Raid 0
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Graphite 760T
    Power SupplySeasonic Platinum 860W
    Keyboard Logitech G910 Orion Specurum
    Mouse SteelSeries Rival 700
    Headset Sennheiser HD8-DJ
    Mouse Pad Roccat Hiro+
    Headset/Speakers Microlab SOLO 9C
    OS Windows 10 Pro X64
    Apr 2014
    30
    RVE10 - PCI-E Light switch dosen't work
    I'm having a weird issue with my Rampage V Edition 10.
    I have a GTX 1080 ti occupied in the first PCI-E Slot and the light on the pci-e switch dosen't turn on to indicate that this slot is populated by a device (Slot 1).
    I can POST and boot into the OS (Windows 10) with no issues and everything run just fine. Even in BIOS i have an indication that this slot is active on 16X in NB PCI-E config. The GPU Post however, dosen't show that any Graphics card is connected.
    Tried to reset the BIOS, nothing. Tried to turn off the PC, removing the power plug and press the turn on button for a 60 seconds, still nothing.
    Sometimes it works but sometimes it's not (for now it's not working for 2 months but worked occasionaly before).
    I do use the M.2 Slot for an NVMe SSD but still even with the SSD pluged in the indicator worked before.
    Graphics card works just fine on 3.0 16X inside Windows 10. Tried everything even reseating the graphics card (kinda hard as the 1080 ti is under water without draining the system).
    CPU: 6900K
    RAM: 4X16 HyperX Predator DDR4 3000 Mhz
    BIOS: 1903 Latest beta bios
    OS: Windows 10 Pro 1803
