Results 1 to 8 of 8
    New ROGer Array
    May 2018
    2
    EZ Flash bricked my C6H. Tried everything. Need ideas
    Hi there
    As a topic said - EZ Flash killed my mobo
    I have next rig:
    Ryzen 1700e C6H
    G.Skill Trident Z rgb 3000 Mhz. kit of 2*8
    Everything was fine on 1201 until I decided to update it to 6004 via "EZ Crash"
    I chose the .CAP file and after verifying new bios system started usual flash procedure (at this time I left the room with PC for 10 mins) and after I came back I've noticed that monitor is in sleeping mode (no hdmi signal) and PC is ON.
    I pressed the reset button and then I got a message on my display something about «system in recovery mode. Insert USB or CD with BIOS file»
    I inserted again my USB Drive with 6004 that I tried to flash 10 mins ago and flash has started again. I was looking at progress and everything went without any errors. Then PC rebooted and I got (and still have) 0d Q-code. (sometimes it shows 01 and 03 codes)
    That what I tried to fix this:
    moved RAM stick to other slots (also tried without any RAM)
    unplugged every single cable except ATX and 8-pin CPU connectors
    unplugged and plugged back the CPU
    removed battery cell for 20 mins
    pressed reset and clear CMOS button until my finger gets hurt.
    But this is a half of problems with thit square $250 POS.
    In theory, these problems can be resolved by BIOS Flashback feature. But it also doesn’t work!
    I tried 3 different USB Drives with FAT32 (also I tried «Bios renamer» by ASUS software) and plugged them in every single USB slot that this mobo has but «bios update» button after pressing and holding it for several seconds just still blue (it should be flashing blue).
    My USB Drive has a LED indicator on it and when I press "bios update" this indicator even not blink so this mobo not even trying to scan USB Drive for C6H.CAP file.
    I think USB slots doesn’t powered (but they should be when PSU is plugged and mobo is in standby mode)
    I'm out of ideas now
    Thank you for reading this lowly literate post (Eng is not my native one) and I hoping that "collective mind" will allow me to make some progress with this "top of technologies" by ASUS.
    ROG Guru: Yellow Belt Array lightknightrr PC Specs
    MotherboardAsus Crosshair VI Hero WiFi
    ProcessorAMD Ryzen-7 1800X
    Memory (part number)F4-3200C14D-32GTZ
    Graphics Card #1Radeon Vega Frontier Edition
    Sound CardHT Omega eClaro
    MonitorSamsung 4K
    Storage #1Samsung NVMe SSD 960 PRO 1TB
    Storage #2Crucial MX200 1TB SSD
    CPU CoolerCorsair H115i
    CaseThermaltake Chaser Mk-1 (Modified)
    Power SupplyThermaltake Toughpower DPS G RGB 1500W Titanium
    Keyboard Corsair K95 RGB PLATINUM
    Mouse Corsair Scimitar Pro RGB
    Mouse Pad Corsair Gaming MM600 Dual Sided Aluminum Gaming Mouse Pad
    OS Windows 10 Pro 64-bit OEM
    Accessory #1 Firewire Expansion Card
    Accessory #2 Black Magic Intensity Pro 4K
    Accessory #3 Mailiya USB 3.0 5-Port Expansion Card
    lightknightrr's Avatar
    Jan 2017
    144
    BIOS reprogrammer. Get one with clips (the thin one) from Amazon, or eBay.
    ROG Guru: White Belt Array
    Aug 2017
    121
    He don't need reprogrammer but to read how to perform correct flash procedure via flashback (could be found in main BIOS thread here).
    ROG Guru: Yellow Belt Array Clouseau PC Specs
    Clouseau PC Specs
    MotherboardCrosshair VI Hero
    Processor1700X @ BCLK-102.0 | 38.25 multi @ +0.03750
    Memory (part number)F4-3600C16D-16GTZ @ 3468 C14
    Graphics Card #1ROG STRIX OC GTX 1080
    MonitorASUS PA248Q
    Storage #1Samsung 960 EVO
    Storage #2Samsung 850 EVO
    CPU CoolerNoctua NH-D15 SE-AM4
    CaseThermaltake Core X9
    Power SupplySeasonic Prime SSR-1200PD
    OS Windows 10 Pro RS4(1803)
    Clouseau's Avatar
    Jun 2017
    142
    Flash Back option needs a plain old USB stick that is 2.0 compliant; nothing more, nothing less. Not all controllers on USB 3.0 sticks function correctly with this feature.
    New ROGer Array
    May 2018
    2
    Quote Originally Posted by BlackBishop View Post
    Thank you for reply!
    I found these steps you talking about.
    ) Change UEFI filename as C7H.CAP or C7HWIFI.CAP depending on your model.
    ii) Copy to USB stick, it must be formatted to FAT32. File must not be in a directory.
    iii) Load UEFI defaults prior to doing flashback and let mobo repost and shutdown.
    iv) Make sure USB stick is in Flashback port (marked in red box below image)
    v) Press and hold the Flashback button (blue box, above image) ~5secs. Blue LED on the button will flash slow for a few seconds
    I did the same. Blue LED on the button just stayed still blue. Without flashing. There's something else
    Quote Originally Posted by Clouseau View Post
    All 3 my USB sticks are pretty old and v.2.0 (4\8\16Gb). Some other reason here...
    P.S. Can anyone check availability of voltage in BIOS flashback USB port in standby mode? It's pretty simple. Just need to turn off your PC and connect to flashback port any device (an iphone for example) and check will it be charging or not.
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)Lenovo
    MotherboardROG Maximus IX Extreme, 1301
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C17Q-16GVK
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #3GPU Tweak II 1.9.7.1 works, no GPU volt monitor since Version 2.8.3.0, shows in LN2 mode only
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK Kit L360
    CaseINWIN 707
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1903
    Network RouterGeneric
    Accessory #1 ASUS Fan Extension Card
    Accessory #2 ASUS Blu-Ray Drive (BW-16D1HT)
    Accessory #3 ROG 10GB Express
    Jan 2016
    130
    Blue LED just stayed blue
    That happened to me when I tried to flash the VIII Formula (M8F.CAP) with the VIII Gene (M8G.CAP).
    Use C6H.CAP instead for Crosshair VI Hero. C7H.CAP is for Crosshair VII Hero.
    In the English manual for the Crosshair VI Hero motherboard the procedure for USB BIOS Flashback is on page 2-13.
    I hope this works.
  7. #7
    Clouseau PC Specs
    MonitorASUS PA248Q
    Clouseau's Avatar
    Jun 2017
    142
    Will check when get home...about three hours
    When I have used the flashback option, the bios file would be copied as is to the stick
    Then renamed the file by pressing F2. File extension was not touched.
    Flash Back never liked any file that renaming tool was used on
  8. #8
    Clouseau PC Specs
    MonitorASUS PA248Q
    Clouseau's Avatar
    Jun 2017
    142
    Quote Originally Posted by SeniorLopata View Post
    ...P.S. Can anyone check availability of voltage in BIOS flashback USB port in standby mode? It's pretty simple. Just need to turn off your PC and connect to flashback port any device (an iphone for example) and check will it be charging or not.
    My phone charged without issue when the USB charger cord was connected to the flash back port while the rig was powered off.
