Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
  1. #11
    ROG Guru: Orange Belt Array MonsterMawd's Avatar
    Apr 2011
    70
    480
    That's location for the GPU with this do-it-yourself vertical mount. The final GPU will have water block.
    Next stage is modifying the top rear portion of the Enermax Equilence case to hold two water reservoirs to emulate the rear fuel tanks on the falcon XB.
  2. #12
    Apr 2011
    70
    480
    To emulate the rear fuel tanks in Max's Ford Falcon XB, I'm using EK-RES X3 150mm reservoirs. btw, these photos are stills from video I'm making of the entire build, once it finished for my YT channel, https://www.youtube.com/user/MonsterMawd
    I'm wondering if I can use clips from the movie without audio in my video? no clue...
  3. #13
    Apr 2011
    70
    480
    Do you recall the Red pull switch on Max's stick shift for his Supercharger? I thought it would be fun to somehow implement it into my Mad Max tribute build. The switch is used in commercial vehicles for controlling a two-speed axle assembly. I found it on Ebay as Cole Hersee part number 50036-BX.
  4. #14
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,516
    Nice find!
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  5. #15
    Apr 2011
    70
    480
    What do you use for cutting small holes? I made this guide for Step Drill Bits
    https://www.youtube.com/watch?v=cVs3tLZQZ6g
    I found Max's Falcon rim in web search attached Nikko Toyota HiLux 4WD R/C truck, but I'll check the R/C Hobby Stores
    Our scale V8 sitting next to Black ICE GTX 80mm radiator. This morning I found 36mm thick 80mm radiator online shown below. Suppose Flex tube loop would be appropriate.
  6. #16
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    301
    7,516
    Quote Originally Posted by MonsterMawd View Post
    Last time I drilled some holes for bulkhead pass-through fittings I used a hole saw designed for deadbolt lock holes. Happens to be the right size. Step bit is more versatile though.
  7. #17
    Apr 2011
    70
    480
    Ahhh, I could see using that! Had some time to get progress in yesterday. The Black Ice Nemesis GTX 80mm radiator may have won me over, instead of the scale appropriate generic radiator I was considering. It also allows options for different compression fittings, versus the welded ports.
  8. #18
    Apr 2011
    70
    480
    I'm going to cut the top panel again and rotate the 80mm radiator 90 degrees, so the radiator is no longer protruding so high. I stumbled upon this hydraulic shock in my junk drawer and used it as support for the scale engine. I may replace it with something else if/when it feels right. btw, the supercharger in the movie could be turned on and off via an electrical switch, which isnt true in reality. They elevated the supercharger upon brackets over the engine with an electric motor, haha. The photo below illustrates the same electric supercharger setup as the movie.
  9. #19
    Apr 2011
    70
    480
    I might fabricate a hood as well. I made scale vette stingray cowl duct hood in 2005 with sheet metal and body filler
    Yesterday I cut the top panel further so I could rotate the 80mm radiator onto it's side. It just protruded too much. I want the supercharger and blower to be more of the focal point, just a little OCD? maybe... haha
  10. #20
    Apr 2011
    70
    480
    The Max mod is consuming my bench space, haha. Last night I cut opening in the 5.25 bay to route the tubing from the 80mm radiator
Tags for this Thread
