Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
  1. #21
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600
    Memory (part number)16GB DDR4
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,346
    Your shop bench still looks cleaner than mine.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  2. #22
    ROG Guru: Orange Belt Array MonsterMawd's Avatar
    Apr 2011
    70
    479
    Ahh, it means youre BUSY!!
    Cutting opening for the radiator lines, finishing edges with Black u-channel molding trim
  3. #23
    Apr 2011
    70
    479
    yesterday, I found time to make mounting bracket from 20 gauge steel for the 80mm radiator
  4. #24
    Apr 2011
    70
    479
    Do you guys keep the factory fans you pull from cases? I honestly ask myself why I keep them?
  5. #25
    xeromist PC Specs
    ProcessorAMD 2600
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    294
    7,346
    That's a big collection. Maybe you should thin it out just a little at least. Maybe a free geek type of place would want them?
    I do keep all working fans because I'd rather put cheapies in an old machine when I sell it off if it had some more expensive fans. But I only have maybe 10-20 sitting in a box.
  6. #26
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    I have lots of fans laying around but not sorted in drawers, just laying around in boxes, or closet
  7. #27
    Apr 2011
    70
    479
    Great idea, I'll look into a Free geek type place for donations
    As promised, I'm ditching the scoop on the scale V8 and making the Scott Superslot fuel injector scoop from Max's V8. I started by makingthe top and bottom portions from acrylic, but getting the 45 angle degree bend from acrylic is "challenging" without the acrylic warping. I ditched that idea and made another bottom half from 20 gauge sheet metal. Which reminded me I really need a new bending brake. The two pieces are joined together with Scotchweld DP-190 epoxy. I need to make the base next, and maybe add the fuel lines.
  8. #28
    Apr 2011
    70
    479
    haha, the details are the fun part! Scoop done, Everything on the engine needs to be painted Dark Silver Aluminum
  9. #29
    xeromist PC Specs
    ProcessorAMD 2600
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    294
    7,346
    Imagine 20 years ago telling someone that modifying a computer case could involve extensive miniatures work.
  10. #30
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Imagine 20 years from now telling someone that modifying a computer case was even possible.
    [/Korth]
Tags for this Thread
