Results 1 to 6 of 6
    ROG Member Array
    May 2018
    6
    Exclamation Problem with GM501 HELPPPPPPPPP!
    I just bought a GM501 BestBuy version, but it should have the same config as regular GM501 without G-sync or 144hz, or that's what I believe... I am having problem with my new laptops.
    1 RGB keyboard: already update drivers through ASUS site, try installing Core Aura and Aura, but neither of them launch successfully
    2 Slow internet: I am using a 200mbps plan, the internet speed on my PC or my 8 yrs old laptop is constantly above 100mbps. However when I use usb ethernet port (starttech USB 3.0) to connect to my GM501, the speed drops to around 20mpbs. It took me 1 day to download BF1 while it was 30-45mins on my PC...... Is it supposed to be like that for a GM501? If so, I am gonna return this laptop ASAP. Not having an Ethernet port is fine by me, but the speed through USB 3.0 is way too slow.
    I am thinking to reinstall Window 10 or test my usb hub with another lap....
    Someone please help, I really like this laptop but missing features to manage RGB colors and getting slow internet are too much to bear. TY.
    ROG Member Array
    May 2018
    6
    Just bought a new GM501 from Bestbuy. Other than 120hz monitor and gtx 1060 6gb, the specs look like the same as a regular 501. However, I am having a problem with the internet speed and RGB keyboard control
    Try to install Core Aura and Asus Aura but neither of them start...
    Internet is only 20mbps, while my pc and my 8 yrs old laptop have over 100mpbs. I use a USB 3.0 to ethernet for my GM501
    Have downloaded drivers from Asus as well as running window update.
    Someone please help!! I may have to return this laptop even though I really like it
    Edited post: reinstalled window, internet reach above 100pbs where it should be, I am doubting the cause for my slow internet was because of ASUS DRIVERS.....
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    360
    8,194
    Sounds like an issue with the Startech device or perhaps an incorrect driver. I would check with another PC and also check to see if Startech has a driver for that or something.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    May 2018
    6
    I just check the usb ethernet by connecting it to my PC. It works normally as the speed on my PC using the usb 3.0 ethernet is still above 100 mpbs. BIOS/drivers issues on GM501?
    ROG Member Array
    May 2018
    6
    CLose this thread
    hi moderator, can you close my thread, I have started another thread in the general discussion with more updates for users to follow up. TY.
    On a side notes, I reinstall window and my internet returns to normal speed if not well beyond.... Suspecting ASUS drivers since I have not installed any drivers after resetting the laptop
    ROG Enthusiast Array
    Apr 2018
    30
    just wondering, did you do a wipe partition, and install a fresh windows 10, and manage to get the ROG AURA working?
Tags for this Thread
