Results 1 to 6 of 6
    ROG Junior Member Array
    Jan 2016
    2
    Possibility of Turning/Reusing parts from a (non-working) G551JX laptop into a PC?
    Hello everyone,
    So I've got a ROG G551JX laptop which unfortunately died on me not too long ago. It's out of warranty and the guy at the repair shop I brought it to told me the motherboard suffered a serious short-circuit. Ultimately, it would have been just as expensive to replace it as buying a new laptop would have, so I resigned myself to buying a new one, albeit much less powerful than the G551JX.
    However, now that I'm left with what is for all intents and purposes an expensive paperweight (the laptop doesn't even turn on anymore), I've been wondering what to do with it. Simplest solution would be to sell it for parts online but that gave me the idea of scrapping the laptop for parts and turning it into a desktop PC. I'm assuming the GPU, CPU, Screen, DVD drive, WIFI card and RAM still work fine (and I've already removed the HDD to turn it into an external HDD) so I was wondering whether it would be possible to reuse those parts to save me some costs in building a proper gaming PC? However, with my very limited knowledge in building PCs, I'm not even sure this is feasible, hence why I'm asking you knowledgable lot.
    Any advice would be greatly appreciated!
    Thanks.
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    773
    quick answer: 0 chance.
    you would be better off selling the parts that you can scrape out, and buy a PC.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,123
    Quote Originally Posted by Gps3dx View Post
    Then again nothing is impossible if your willing to put enough money into it. I agree with GPS3DX just buy you a new notebook and save yourself a lot of money and aggravation.
    Notebooks are nothing like desktops that you can just change a few parts, they have all that Desktop stuff jammed into that little 15" notebook most of its soldered in place or just proprietary made just to fit in that notebook
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Quote Originally Posted by SnailVendor View Post
    Quite an assumption since it's a dead machine and "the guy at the repair shop" told you "the motherboard suffered a serious short-circuit". Any component salvaged from an electrically-damaged mainboard is automatically compromised and has dubious reliability. There's a reason the thing won't even turn on anymore. I would expect some sort of evidence supporting such a serious technical diagnosis - maybe point out some of the burnt/killed hardware components, maybe a photograph showing ugly damage, etc - it kinda sounds to me like the guy wasn't interested in even doing the job, didn't know how or didn't think it would be profitable enough, etc. From a customer perspective it's unreasonable to pay more for a repair than the cost of a replacement - and replacement G551JX parts might be available inexpensively if you do some digging.
    Laptops typically have certain modular components - like memory and storage - which can be swapped out and used in other machines. Many have internal parts with standard form factors - Mini-PCIe WiFi card, GPU MXM module, etc - which could be swapped out and used in other machines. The battery can also be used in other laptops within the same laptop brand/model/family. All other parts are usually fully embedded (permanently soldered in place) or follow standard form factors (display panel internal DP ribbon, mobile processor socket, etc) but have hardware specs/quirks which are incompatible with the vast majority of other laptop models/variants.
    You admit that you don't have knowledge or experience with building PCs. Attempting to salvage parts from a dead laptop is not the best place to start - it's a technologically dense machine packed with clever engineering, merely taking the thing apart and putting it back together (properly) will be a challenge for inexperienced people, while troubleshooting hardware faults and extracting internal parts (which aren't easily accessible through chassis access panels) will effectively be impossible. Desktops and laptops basically use completely incompatible hardware - and even if you could turn your laptop parts into desktop parts (it's not impossible if you understand PC hardware and some electronics) you would find that it's not worth the effort. After all, your laptop died and won't even turn on ... and it's out of warranty so it's basically "old tech" which won't make a great gaming computer ... and in the end this sort of project would basically cost you more than the price of a new (and working, and better) computer.
    I advise donating it to a charity like Free Geek, or simply sell it on eBay (as a "dead, for parts" machine). Either way, your dead paperweight might be repaired, refurbed, reclaimed, recycled, and repurposed ... and you can already forget about making money from it, if what you've been told about it is true then it already has effectively zero value. You might want to take it to a different repair shop to get a second opinion, indeed you might even be able to sell it to them ("for parts") or trade it in as credit towards something else.
    [/Korth]
    Jan 2016
    2
    Thank you all for your replies and your great insight. As Koth suggested I took it in to a different repair shop for a second opinion and got pretty much the same conclusion. Guess I'll see if anyone on Ebay wants to buy it otherwise I'll look at donating it to a charity or recycling it.
    Thanks again!
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    The drive(s) and RAM could be used in other laptops. The CPU and GPU might also be useful in other laptops - if they still work, and if they're socketed/removable.
    The battery, screen, and keyboard could be used as replacement parts for other ROG G551 laptops. (Any part could be used as a replacement, if it still works, though these are the parts which most commonly fail/break.)
    [/Korth]
