Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array
    May 2017
    6
    Exclamation Asus G751GY Audio Enhancement disabled
    I have been having this issue for a while now, where the Rog AudioMaxx Audio enhancement is disabled. I have tried uninstalling and reinstalling the audio drivers. This used to work for a short period, wherein, instead of being disabled, it said Audio Device is configured to 8 channels, please configure to stereo mode. However, upon the immediate reinstall of the drivers, I was able to change the enhancement option briefly before it grayed out and displayed the channel message above. Recently though, I cannot even get to that point as any uninstall and reinstall, results in AudioMaxx remaining greyed out and no enhancements available. Any help would be appreciated as it makes a big difference to the sound.
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    773
    Quote Originally Posted by ylair View Post
    AudioMaxx works only for stereo output.
    if you disable any output to external speakers ( analog or digital ) then enable the built-in speakers,
    AudioMaxx should work.
    It might be possible to work on external output as well - BUT IT MUST BE CONFIGURED AS STEREO.
    you can change any audio device by going into control panel -> sound -> playback devices tab -> choose any ANALOG device ( internal/external ) and right click -> configure speakers -> set as STEREO ( i.e 2 channel ) -> then goto
    AudioMaxx and see if it works.
    ROG Guru: Yellow Belt Array
    Nov 2014
    13
    238
    Notice: I have Polish Windows and drivers so some terms might be called differently than my translation.
    I have the same issue from time to time. Audio drivers get "misconfigured" by some games by DISABLING inside Speakers Properties / tab Enhancements the checkbox called "Immediate Mode" that is needed for AudioMaxx to be working.. If OK, it should be checked and NOT grayed out... Some games spoil it by making it greyed out even if checked so not possible to activate it again... I used to reinstall Realtek drivers to fix the problem since nothing else helped... but recently it worked the following way, without any reinstall:
    1st. AudioMaxx is working ONLY for stereo. So go to Realtek HD Audio Manager (can be found at tray or at Control panel) and switch to stereo.
    2nd. Make sure that default playback device are Speakers - Realtek High Definition Audio... so NOT Realtek Digital Output.
    3rd. Go again to Realtek HD Audio Manager - select "Speakers" icon on the top (not Digital Output) and go to tab “sound effects”. Activate some effect like “bathroom”, then select “<none>” at the dropdown list to disable the effect, and then press “Reset” button next to the dropdown list.
    4th. Do the same but at “Digital Output” icon at the top.
    AudioMaxx should be fixed now and "immediate mode" fixed.
    If not… go to services.msc, find service “Windows Audio”, stop it and start again…
    Repeat steps 1 – 4.
    Reboot laptop.
    And check again AudioMaxx.
    Hope it helps!
    ROG Member Array
    May 2017
    6
    Quote Originally Posted by Gps3dx View Post
    Sorry, I did not mention, but my system is configured to stereo and it still used to show the channel message. Right now, Im not even getting a channel error, it simply says disabled in audiomaxx.
    ROG Member Array
    May 2017
    6
    Quote Originally Posted by Sanctrum View Post
    Repeat steps 1 – 4.
    Reboot laptop.
    Hope it helps!
    This helped. Selecting an effect and then removing for both digital output and speakers, seems to have resetaudiomaxx back to the original error "Audiomaxx supports stereo output only, the system is currently configured for 8 channels". Although in this mode the different audio presets such as action are greyed out, I am able to click the settings toggle in the upper right and toggle maxxvolume, maxxaudio, as well as change treble, base, and customize the levels. It displays the box as greyed out, but I can still click these functions and adjust them. In addition, the immediate mode box, is checked and no longer greyed out in the properties for the speakers. Therefore even if I cannot select any of the presets for audiomaxx, I can use the custom tool to boost the audio.
    As you mentioned this was directly tied to a game as well. I play Battlerite and they released a patch which coincided with the disabling of audio. Strangely enough this impacted the games performance with extreme graphic lag. Menu, character and effects delays of 2 seconds. After resetting the sound effects in Realtek Audio Manager, not only has it resolved the primary audio issue but Battlerite is now running smoothly again.
    Any ideas on how to resolve the 8 channel versus stereo error though? My system is configured to stereo. Also, would you be able to tell me what custom settings get selected when you select action mode in audiomaxx so even if I cannot select the preset, I can match it with the custom functionality through the settings toggle. Thank you.
    Nov 2014
    13
    238
    Maybe you have some addtional audio drivers installed? Like Razer Synapse (Razer Surround Audio controller) to simulate 7.1 channels over stereo headphones?
    Are you 100% sure your default audio device is set to "Speakers - Realtek High definitione Audio" and that those drivers are set to stereo?
    If you have Razer Synapse... then it also can "spoil" AudioMaxx in two ways: A. It is set as default driver BUT it is configured to 7.1 channels, B. Some games are IMPACTING Razer Synapse configuration switching "Selected Audio Interface" from the proper one "Speakers - Realtek High definitione Audio" into NOT proper "Realtek Digital Output".
    It would really hepl if you would post some screenshots of your audio devices config (playback devices - not recording devices).
  7. #7
    ROG Member Array
    May 2017
    6
    Screenshots attached.
ID:	73894Click image for larger version.
ID:	73893Click image for larger version.
  8. #8
    Gps3dx PC Specs
    Feb 2015
    71
    773
    you've got a "usb audio" device in the playback devices list.
    DISABLE it, or simply DISCONNECT that external USB audio device.
    then see what audio max status is.
    IMHO, you should expect audiomaxx to work ONLY WHEN THE INTENRNAL SPEAKERS are the ONLY ENABLED AUDIO DEVICE ( so disable the rest ) and the intenal speakers configured as STEREO.
  9. #9
    ROG Member Array
    May 2017
    6
    I disabled it, the rest are already disabled or disconnected but are just shown. No change.
  10. #10
    Nov 2014
    13
    238
    We are getting short of options. Disable all devices. Then enable ONLY those two Realtek devices... Next, set as the default the proper one (first try setting the wrong one).
    Then restart Windows Audio service and redo points 1 to 4 from my first post at thos thread.
    If this won't help I am out of clues. So problably Realtek Audio drivers reinstall is needed.
    However, from your description the problem looks like MaxxAudio in NOT using the proper device somehow... since it thinks 8 channels are still active.
    I had the same mismatch using MaxxAudio with Razer Surround driver... Maybe you have similar problem with USB Audio CODEC device... Maybe this device is listening to the wrong device it should... eg. to Realtek Digital Output - not the second one. Try to play with USB settings. However I do not know what they are and what are the proper one.
    If you decide to reinstall Realtek HD Audio then first make your system "clean" by disabling other audio devices...
    Good luck.
Tags for this Thread
