Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Guru: Yellow Belt Array Spirery1 PC Specs
    Spirery1 PC Specs
    MotherboardAsus Maximus iv/gen3
    Processori73770k
    Memory (part number)20gig 1600mhz
    Graphics Card #1gtx 1070 airboss x4
    Sound CardSoundBlaster Z
    Monitorsamsung Gsync 144 27inch/PG285Q swift
    Storage #1Samsung Evo 850 120GB
    Storage #2Toshiba 2TB
    CPU CoolerAIO Nepton 120XL
    CaseAsus CG 8480 Republic of Gamers tytan
    Power Supplycorsair 550
    Keyboard Logitech G410/G910
    Mouse Logitech G300
    Headset Creative Fatalty
    Mouse Pad Ichill Inno3D
    OS Win 8.1/10 Laptop
    Network RouterTP-Link AC1900 Dual Band Touch Screen
    Accessory #1 EVGA SC 17 4K GTX 1070
    Accessory #2 soundblaster omni/T6300
    Accessory #3 gladius mouse
    Nov 2015
    125
    G752VY high temps using Extreme
    Wondering what temps people get mines the 6820hk and on extreme the cpu goes nuts looks like its thermal throttling on any bench mark get more points on standard then extreme tombraider getting 65+on ultra on standard extreme 80-90c+ but its just the cpu going mad gpu is fine same with finalfanstay online extreme makes cpu mad and thats with fans on 100% as it just came back from its 3rd rma dont want to send it back for a 4th without trying everthing i can any advice would be greatfull.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    A little more info.
    Ambient temps?
    Clean?
    Surface you are using it on?
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    idle 39-40 on both its on a rog mat just came back from 3rd rma its on a desk in are bed room vapor chamber should keep it cool its just extreme temp goes up they replaced mobo lcd both fans and the cpu module alls updated bio's too
    ROG Guru: Orange Belt Array
    May 2011
    28
    390
    Quote Originally Posted by Spirery1 View Post
    Sounds like a mating issue with the heatpipes on the CPU side. Either that or dust. If it just came back from an RMA, I would bet its a bad paste job on the CPU which is unfortunate. That or I would check to make sure the fan they replaced is working as it should. Can you verify air is getting out the back on the CPU side alright and possibly look at the RPMs to make sure they are where they should be.
    It everything checks out, its gotta be a CPU mating issue with the pipes. 90 is pretty high for a 17inch ROG chassis.
    ALIENWARE R17 R5 - i7 8750H - GTX 1070 @ 1.9Ghz - 16GB DDR4 - NVMe 970 EVO 1TB - SSD 960 EVO 1TB
    SOLD: ASUS G703VI-XH74K
    RETIRED: ASUS G752VY-DH72
    RETIRED: ASUS G750JH DB71
    RETIRED:ASUS G74Sx DH72
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    Installled fanspeed GPU 3900 CPU 1386 so thats the problem i always game on ultra with fans on full just for gaming so looks like its 4th RMA in 10 months replace or money back only sent it back second time as it came back faulty All i want is a working gaming laptop well use i know why the temps going nuts on extreme thxs again for the help phone asus in the morning AGAIN!!!!!!!
    Super Moderator Array
    Jan 2013
    99
    2,134
    Not sure if this can help and if you are have these versions already, but make sure you are using the latest ROG gaming center version 1.08 as well as the turbo gear update 1.03 (which may not be necessary depending on your model and ROG gaming center version?).
    If you are having any problems finding the downloads, you may want to check the U.S. G752VY download site below if necessary.
    https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-G752VY/HelpDesk_Download/
    There were some issues with this on the G752 models a while back as below and it's probably not very likely you are running the older software versions, but wanted to make sure.
    https://rog.asus.com/forum/showthread.php?88932-Asus-G752VS-Turbo-gear-update-for-Overheat-Issue
    Check the bios version you are running as well.
  7. #7
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    Using both albert the cpu fan goes to full with just opening firefox then off its low rpm on full CPU 1390 max to 3900 GPU fan but all is upto date but thanks for the help.
  8. #8
    Spirery1 PC Specs
    Processori73770k
    Mouse Logitech G300
    Nov 2015
    125
    whats everyones RPMs? on full cpu and gpu my cpu is 1407rpm and gpu 3900rpms with fans on 100%
  9. #9
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    You may be expecting more than the machine can deliver. Dial back your settings from Ultra.
  10. #10
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    I repasted my own G752VS and on max setting games like ARK, (which has no FPS limit, so it's forcing the card at 100% load, I get 76-78*C on the GPU and the CPU roughly 70-75.
    Rare to see CPU hit 80.
    If you're seeing excessive of 80+ I advise you rip off the plastic cover on the back (not rip off but.. pry it off gently ;d)
    This will promote better flow for your GPU/CPU, at the expense of everything else, but it seems your GPU/CPU will need it more.. so..
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
