Results 1 to 2 of 2
    ROG Member Array
    Jun 2017
    9
    What is the proper way to use External Sound Card?
    I have a Asus Z270 Strix-G Motherboard setup and recently purchased a Soundblaster X-G5 usb Sound Card.
    Curious if there is a specific way to use this in conjunction with the motherboard.
    I keep on having to un-install and re-install drivers for this device because i keep on losing sound and the mic no longer works.
    or
    Is there another DAC/AMP out there that works better with AKG-7XX and Mod Mic 5.0?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,628
    I find that Windows will sometimes change the default audio device (in my case it changes to my monitor, which isn't connected to speakers) so before you re-install you might want to check the default device. Easiest way is to right click the speaker icon in the system tray and go to Playback Devices.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
