Results 1 to 10 of 10
    ROG Member Array
    May 2018
    8
    ASUS RoG Strix B350-F Gaming Mobo draws too much power when shut down
    I just got a new build going this last weekend with this motherboard. Everything works great except for when I shut down the computer. I have my PC hooked up to a master outlet in the surge protector and my monitors and speakers are connected to the controlled outlets so they turn off when the computer turns off, at least that's the way it used to work.
    With this mobo, it draws enough power when shut down to still keep the controlled outlets going. I've tried disabling the LEDs on the mobo but still have the same issue. Any ideas if there is some setting I can change so the master outlet will shutdown when the computer shuts down?
    ROG Member Array
    May 2018
    8
    bump
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus IX Extreme
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1909
    Network RouterGeneric
    Accessory #1 ROG Aura Terminal
    Accessory #2 ROG 10GB Express
    Accessory #3 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Jan 2016
    199
    Advance Menu/APM Configuration/ErP Ready/enable (S4 +S5) turns off my computer (Motherboard LEDs, USB ports, graphic card power LEDs, etc.), but I have to turn off my monitors and speakers separately. I do not use a surge protector, so I do not know how that would work.
    ROG Member Array
    May 2018
    8
    Quote Originally Posted by pndiode View Post
    Yeah, I have that turned on so that the leds and everything turn off, but it still draws enough power when shut down that it keeps the surge protector on unfortunately.
    ROG Member Array
    May 2018
    8
    Anyone else have any ideas?
    ROG Member Array
    May 2018
    8
    bump
  7. #7
    ROG Member Array
    May 2018
    8
    bump
  8. #8
    ROG Member Array
    May 2018
    8
    No ideas?
  9. #9
    ROG Member Array
    May 2018
    8
    bump
  10. #10
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    PSU and pc always have power and leds ( and other components that need power even the pc is turned off ) will draw some power.
    if you want to fully turn it off i sugest pulling power cord.
