Problem Aura Sync
betolenz
Config PC:
Asus ROG Strix B350-F Gaming AM4
AMD Ryzen 1700
BIOS V 4011
SO Windows 10 PRO x64 Build 1803 / Compilation 17134.81
Memory Kingston Hyperx Fury 2400mhz
VGA RX 470 PowerColor Red Devil
Mouse Motospeed V20
Keyboard Motospeed CK104
WC PCYes Sangue Frio 240mm
Aura Sync V1.06.17
Problem description:
I have this board a short time (4 months +/-) since I always bought the Aura Sync system, both the heatsink lighting and the 5050 led strip I installed in the case (4-pin connector).
2 weeks ago I tried to do a SSD RAID 0, without success because the performance did not please me (they were different SSD's), then I undid RAID, I went back to AHCI mode, I installed Windows normally on 1 single SSD, downloaded and installed the drivers from the manufacturer's website and set everything up correctly. But Aura Sync stopped working. I reinstalled the drivers, reset the bios and nothing. I formatted the pc again, reinstalled everything and nothing.
You have a bios option to disable or enable the RGB controller, I've already moved on it and I was not successful. Normally when I turned on the pc, it was already lighting the heatsink, even before I started windows, and now no sign of life, that is, it is not a driver problem.
Sorry if the pronunciation is not correct, because I'm using the translator, I'm Brazilian. 😛
Photo of bios:
74040
yoyo_yoyo
Yeah Aura 1.06.17 is a dud!
My ASUS Strix lighting has stopped working with current version of AURA. Works fine with older versions.
SPECS:
Ryzen 1700X
ASUS X370-F Gaming (4011)
ASUS Strix GTX 1080 Ti
GSkill Trident Z RGB F4-3200C14D-16GTZR
AURA 1.06.17
Windows 10 Pro X64 (1803) Build 17134.81
SPECS:
Ryzen 1700X
AURA 1.06.17
Hello Friend. I have already installed older versions, including the one that came along with the cd of the motherboard and did not solve the problem. I'm thinking it might be a hardware defect, so I'll have to get the card for the warranty.
