ROG Gladius II Aura Sync color shifting ahead of everything else?
Kalmus
Hi guys, so I have a Rampage V Edition 10 motherboard with 5 things connected to the RGB header and the other additional Aura-compatible components:
  • 2 short LED strips on graphics card waterblocks
  • an RGB element in the EK monoblock
  • a short RGB strip on the inside of the case
  • the RGB strip in the EK pump/reservoir combo
  • G.Skill Trident-Z RGB RAM (4 DIMMs)
  • ROG Claymore keyboard
  • ROG Gladius II Origin mouse
In Aura (the only software that I can get all of these to show up in) I have everything synchronized and use the color shift pattern.
However, the mouse always color shifts slightly ahead of everything else, so as the system is running over time it ends up being completely out of sync with the rest of the system.
Is this a known issue with the Gladius II Origin? and/or is there some way to correct it? The mouse seems to work fine, other than this color sync problem.
0 REPLIES 0
