06-04-2018 05:23 PM - last edited on 03-06-2024 07:55 PM by ROGBot
06-05-2018 04:48 PM
06-05-2018 04:51 PM
06-05-2018 05:21 PM
egonzalez7579 wrote:
Try this https://rog.asus.com/forum/showthread.php?102475-ROG-AURA-Service
06-05-2018 05:24 PM
06-06-2018 02:11 PM
Might need to try costumize
06-06-2018 02:19 PM
pikapool wrote:
I tried everything with your files and many other combinations and this did not work for my GU501GM. Pressing any of the buttons causes the Aura app to freeze.
Even after over 10 emails, Asus support does not understand when I ask them to just please provide the Aura Core software that comes new with the laptop. All they have to do is make it available on the GU501GM page. Starting to get really frustrated.
06-06-2018 09:41 PM
Im my case i have to click costumize, then select a scheme,
Other is, reset to factory, if need, you can use my uploaded images
06-07-2018 05:30 AM
pikapool wrote:
Thanks for all your help! I don't want to reload everything and Aura Core 1.04 works well enough for me. Just to be safe though, I downloaded your images and files. Hopefully Asus steps up and just provides the Aura Core files needed as that would be the simplest solution. I don't know why they are making this so hard.
06-07-2018 10:03 AM
tap002 wrote:
pikapool, I just installed AacSetup.msi; AuraServiceSetup.msi and it worked perfectly (GL703GE i7 8750H 8th gen). According to a post by dedynarna: https://rog.asus.com/forum/showthread.php?102838-about-RoG-GameVisual&p=722687#post722687 you also need ROG Aura Core Component. This is a utility available for download under a couple of GL models. GL703GE: https://www.asus.com/us/Laptops/ROG-Strix-GL703/HelpDesk_Download/ Might be worth a try?
