Asus rog gl503vd battery life
arch_simbahan
Hi, I just bought my new laptop Asus ROG gl503VD. But within in a span of 40 mins the battery life goes down. I tried to back the product to the store where I purchased it. But they said that there's nothing wrong on my laptop battery, after they burn test. So i WOULD LIKE TO ASK IF WHAT CAN I DO TO EXTEND THE LIFE SPAN OF MY BATTERY? EVEN THOUGH IT IS FULL CHARGED AND I DIDNT USE IT, THE BATTRY STILL GOES DOWN TO 0.. THANKS. HOPE SOMEONE WILL HELP ME!
Bill
Hello arch.simbahan;
I don't understand your issue. There are many factors that will effect battery consumption. It depends heavily on how you use your laptop. Of course, it will consume power even when you put it in idle, so it's completely normal that it will use up battery to 0 even if you are not using it when it's on.
