Don’t be shocked, but chances of a fix are after years of complaining ZERO DOT ZERO.
We (the whole community) complaining for years about this, and many other bugs with the Ai Suite. The Fan Xpert is completely useless. When you finally are able to make a working profile is suddenly is back to default.
Most of us are tired to complain. I’m using MSI now.
For now, just don’t use it! When Windows comes with a new update it won’t work again, and you get lots of BSOD.
Just deinstall, and remove all processes manually (they won’t deinstall automatically. There’s also a Ai Suite removal tool, but guess… That’s not working anymore after the Windows updates.
Control your fans with the motherboard qfan. It works good, and for now the only good solution.
