Results 1 to 10 of 10
    New ROGer Array
    Jun 2018
    2
    Crosshair VII internal USB 2.0 / USB_15 -problem
    i have a minor problem with my C7H-board. The internal USB_15 (the part of the ROG-extender) doesn't seem to work properly. If i connect t to an AiO-USB-cable, then windows 10 doesn't recognize the AiO-cooler (the other USB-connector does). If I connect the USB 2.0 -cable for the casefrontpanel to the US B_15 slot, then the panel does work...but only half of the USB-slots do.
    The question is, if this is a common problem or if the connector on my board is broken. Since i rarely use USB 2.0 it isn't really a big issue. But if I pay $300 for a MB, then I want it to work to it's full extent.
    Yea I know I could simply RMA it, but the place where I got the board from doesn't have a new one for the next month or so and sending it directly to asus would take ages as well.
    ROG Junior Member Array
    Jun 2017
    11
    2
    I thought that too. Already took steps to open up a RMA while being super unhappy as I bought the C7H as my C6H slowly died, thinking I had two faulty parts in a row.
    Anyways, open up your manual, the USB_15 header has only 1 USB 2.0 port connected, the second row states NC (not connected) on the data lines. It's actually just meant as being part of the ROG Extension port. There's also a second USB header to the left of it, USB_1112, which is the *true* USB 2.0 header with 2 active ports. I would assume that the second USB port on the USB_15 header is the power supply for the extension kit, as only +5V and Ground are connected.
    Anyways, here's the relevant manual part: https://imgur.com/gallery/KUgqD5w
    ROG Enthusiast Array Delta9K PC Specs
    Delta9K PC Specs
    MotherboardMaximus X Hero (Wi-Fi AC)
    Processor8700K Delidded 5.1GHz
    Memory (part number)CMD32GX4M2C3200C16
    Graphics Card #1ASUS ROG-STRIX-GTX1080TI
    MonitorASUS ROG SWIFT PG279Q
    Storage #1Samsung 960 EVO - 500GB NVMe
    Storage #2Samsung 860 EVO 1TB
    CPU CoolerCorsair H150i
    CaseCorsair Obsidian 500D
    Power SupplyCorsair HX1000i
    Keyboard Corsair Strafe MK.2
    Mouse Logitech G403
    Delta9K's Avatar
    May 2018
    16
    71
    There is nothing wrong with the USB15 header as Thercon Jair correctly stated. That header is a single port. You can get a hub or a splitter to connect to USB1112. Many have had success using the NZXT hub and it is inexpensive @ $20. You could also use a commander Pro but @$70 it may be a bit overkill just to get two internal headers from one. Another inexpensive option is a USB splitter like this < https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 > @ 10.00 on amazon and you can find them elsewhere just search for USB internal 9pin splitter 1 to 2 male.
    Or if you are cool with it leave the AIO in USB1112 and connect the front USB 2.0 i/o to USB15 and just know that one of your front 2.0 sockets wont work. I imagine you would need two front USB 2.0 simultaneously on very few occasions.
    Other systems in addition to the gaming rig in the profile specs:
    Crosshair VII (WiFi), 2700X, 32GB GSkill c14 @3200 , 960Pro 512, 860Evo 1TB, GTX1080ti, HX850, Celsius S36, Define R6, pg348q
    x470 Taichi, 2700X, 16GB GSkill c14 @3200, 960Evo 500, 860Evo 1TB, GTX1080, RM850x, Celsius S36, Define R6 usb-c, dell u3415w
    New ROGer Array
    Jun 2018
    2
    Thanks for the answers. I've missed the "NC" part in the manual. I had my suspicions, that the reason USB_15 doesn't work all the way, was because it was a part of the ROG-EXT.
    The part, which threw me of is, that I also have the C6H and the ROG-extension-USB-port works fine with AIOs and 2 USB-ports.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    1,000
    I personally have had great success with THIS HUB.
    Davemon50
    Dec 2018
    45
    2
    Guys i just resolve the problem xD if you can see hier https://imgur.com/gallery/KUgqD5w at the 5 pins the are NC but at the 4 pins they are all ative! USBP15- and usb P15+ And any way the 5 pin dont need to work any way! so yea you just need yo use the 4 pins not the 5 pins my h110i is working that way!
  7. #7
    Dec 2011
    354
    25,742
    Thanks Loviless for posting your fix. I hope you don't mind if I copy that tip and add it to my growing book of fixes...
    Have added to your rep mate.
  8. #8
    ROG Guru: White Belt Array Rewerend PC Specs
    Rewerend PC Specs
    MotherboardAsus Crosshair V Formula - Z
    ProcessorAMD FX-9370
    Memory (part number)2 x KHX23C11T3K2/8X
    Graphics Card #1R9 Fury X 4gb Sapphire
    Sound CardAsus Xonar Phoebus
    MonitorSAMSUNG U28E590D 28" uHD + freeSync
    Storage #1Samsung SSD EVO 540 250Gb
    Storage #2Seagate 7200.14 2TB
    CPU CoolerCorsair Hydro H105
    CaseCooler Master Cosmos II
    Power SupplyENERMAX ERV1000EWT-G Revolution87+ 1000W Gold
    Keyboard Microsoft SideWinder X6
    Mouse Saitek MAD CATZ R.A.T. 7
    Headset Asus ROG Orion
    Mouse Pad Steel Series PAD
    Headset/Speakers Genius Home Theather SW 5.1
    OS MS Windows 8.1 Pro
    Network RouterAsus RT-N18U
    Accessory #1 Zalman ZM-MFC3 FAN/TEMP CONTROLLER
    Jun 2014
    79
    Quote Originally Posted by Thercon Jair View Post
    Regaring to your post I have Cosmos II case with 4x USB front panel and I was curious why only 3 from 4 USB are working with data and fourth only blinks power of the USB stick and your post makes sense for me. I checked wiring inside the cable, I am asured that USB panel is OK just internal USB_15 only supports data for one USB and second one can only power up through USB.
    It´s weird that ASUS made it like this, my old Crosshair V could use 4x internal USB with data.
  9. #9
    ROG Member Array Rufinoman PC Specs
    Rufinoman PC Specs
    Laptop (Model)Lenovo
    MotherboardAsus ROG Crosshair Hero VII WiFi
    ProcessorAMD Ryzen 2600X
    Memory (part number)32Gb CMK16GX4M2A2400C16
    Graphics Card #1Asus ROG Strix RX580 OC 8Gb
    MonitorSamsung C27F591
    Storage #1WDS500G2B0B
    Storage #2Samsung SSD 850 Evo 250Gb
    CPU CoolerCorsair H100i RGB Platinum
    CaseCoolermaster Storm Trooper
    Power SupplyCorsair RM850x, Full Modular
    Keyboard Corsair Strafe RGB Silent
    Mouse AFX LM0218
    Headset Corsair HS40
    Mouse Pad Razer
    Headset/Speakers Corsair HS40
    OS Windows 10 Pro x64
    Dec 2017
    20
    I was wondering the same and thanks to Thercon for being so eagle eyed and spotting the USB15 NC in the manual, thus putting my mind at rest.
    My Storm Trooper case has two front USB 3.0 and two 2.0, so it's no great issue for me.
  10. #10
    ROG Member Array
    Jul 2018
    12
    17
    Burned by a necro
