Results 1 to 9 of 9
06-11-2018 10:53 AM #1
Frostie36 PC Specs Motherboard Crosshair VII Hero X470 WiFi Processor Ryzen 2700x Graphics Card #1 Evga 1080TI FE Sound Card Creative X-Fi pcie Monitor Asus VG278QR Storage #1 Samsung 840 Pro 256mb Storage #2 Samsung 850 Evo 1TB CPU Cooler Noctua NH-U12S SE AM4 Case HAF 932 Advance Power Supply Silverstone Strider 1000w Keyboard Logitech g15 v2 Mouse Logitech G502 Headset/Speakers Creative Headphones OS Windows 10 Pro X64 Network Router Netgear WNDR4500
- Join Date
- Apr 2017
- Reputation
- 10
- Posts
- 43
Crosshair vii hero ethernet port issue
Hi All,
So I finished building my new ryzen rig using the crosshair vii hero board and thought after putting it all together the ethernet port appeared dead, router was indicating no cable was connected and in windows no ethernet was even showing up in the device manager under network so of course the driver wouldn't install as it could find any suitable hardware.
After much head scratching and as it was the early hours of the morning I gave up fault finding for the night & upon powering up the system this morning the ethernet port was working, I could tell straight away after hearing the bios beep code for a successful post as the light on the router changed from orange to green to indicate cable detected and sure enough in windows the lan hardware was showing in device manager and I was able to get the drivers installed.
So after that was all sorted I decided to see if I could get my ram running higher than 2800 MHz (using 4 sticks that aren't on the qvl list, yes I know but I was trying to keep costs down swapping from intel back to amd so I used the ram I was using on my previous intel build) and after the post failed due to a failed memory overclock I returned back to 2800 MHz and all was well again, except the lan port was again non functioning!!. I rebooted, still not working so then I turned off the pc for a few seconds, turned it back on and voila, ethernet port was working again and testing numerous reboots and power offs afterwards it kept working so what I've discovered is that if my board goes through any kind of memory training after changing ram speed etc then the ethernet port doesn't function until I power down the system & restart it.
That sounds like a bios issue to me rather than a faulty ethernet port, has anyone else experienced similar issues with the ch6 board?
06-11-2018 07:48 PM #2
schweigert PC Specs Motherboard Asus Crosshair Hero VII Wifi Processor AMD Ryzen 2 1700x Graphics Card #1 AMD RX 480
- Join Date
- Apr 2018
- Reputation
- 15
- Posts
- 32
this is a common issue people are reporting on the CH7 boards - at least 6 people have posted the same issue here - Asus has been quite on it.
06-12-2018 11:36 AM #3
michaelemcken PC Specs Motherboard Crosshair Vii Hero WiFi Processor Ryzen 2700X
- Join Date
- May 2018
- Reputation
- 10
- Posts
- 23
What PSU are you using?
06-12-2018 01:17 PM #4
- Join Date
- Apr 2017
- Reputation
- 10
- Posts
- 43
07-05-2018 10:28 PM #5
Sedare PC Specs Motherboard ASUS ROG Crosshair VII Hero X470 Processor Ryzen 2700X Memory (part number) G.Skill F4-3200C14D-32GTZR (4 sticks) Graphics Card #1 Galax GTX 970 HOF Sound Card Creative Soundblaster X7 (external Amp/DAC) Monitor ACER XB270HU 27" G-Sync Monitor Storage #1 WD Black 500GB NVMe PCI-e SSD Storage #2 WD Black 1TB NVMe PCI-e SSD CPU Cooler EKWB C6H Monoblock Case Lian Li PC-O11 Dynamic Power Supply Seasonic Prime Ultra Titanium 1000W Keyboard Corsair K70 RGB (Brown Switches) Mouse Logitech G502 Proteus Spectrum Headset Senheiser GSP600 Mouse Pad Corsair MM800 RGB Polaris Headset/Speakers E-MU XM7 Bookshelf Speakers OS Windows 10 Pro 64-Bit Network Router ASUS RT-AC87R
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 50
I'm having this issue as well. I have the C7H WiFi and I cannot get my ethernet port to be recognized to install drivers. I have 4 sticks of "non" AMD ram too and did the DOHCP deal but windows didn't like it. I went back to stock and it boots but no ethernet to install drivers no wireless being recognized, etc.
07-05-2018 10:32 PM #6
- Join Date
- Apr 2015
- Reputation
- 10
- Posts
- 50
And yep, I just now did what you did in terms of turning off the computer fully (not just a reboot) and then waited 10 seconds, started back up, and the drivers installed fine AND my wireless network shows. WTF. Am I hosed on this G.Skill RGB Ram with not being able to clock it to the rated 3200MHz and/or have internet access?
07-13-2018 08:27 PM #7
- Join Date
- Jul 2016
- Reputation
- 10
- Posts
- 2
Same issue here... no WiFi or Ethernet.... I rolled back to BIOS Version 0401, with that one i have network atleast...
Also i noticed that when i had the latest bios all of the BIOS menus were super slow to go trough~3-5 sec to switch from one option to another in the BIOS.
No matter what BIOS version my G.Skill memory can never reach the rated 3200MHz (I have spare Intel CPU and motherboard where it works there though....)
I see some people say that it might be the PSU... I tried using: EVGA SuperNova 850 T2 Titanium and EVGA SuperNova 1000 T2 Titanium and still no network... with the latest BIOS..
FeelsBadMan
My full specs:
ROG CROSSHAIR VII HERO (WI-FI)
AMD Ryzen™ 7 2700X
64GB (4x16) G.Skill 3200MHz
nVidia GTX 1080
EVGA SuperNOVA 850 T2, 80+ TITANIUM
07-15-2018 02:02 PM #8
Try disabling Fast Boot in both the BIOS and Windows. I'm having the same problem - this has made it so that my network adapter appears on startup following shutdown, but it still disappears after a restart.
Corsair AX1600i here, so I don't think it has anything to do with the PS. BIOS version 0702 (latest as of this posting).Last edited by cg49me; 07-15-2018 at 02:06 PM.
07-16-2018 08:11 PM #9
- Join Date
- Jul 2018
- Reputation
- 12
- Posts
- 31
This is going to sound a little silly but I had the same issue and fixed it with this. Symptom was NIC would completely disappear from windows. When this happened first cleared the CMOS. When that didnt fix it I reseated the ethernet cable in my router and yet again no fix. I then switched which port it was plugged into on the router and all the sudden windows detected the NIC again. I then moved it back to the original router port and it worked fine.
No idea what happened here but wanted to share.
