Results 1 to 2 of 2
    New ROGer Array MHack PC Specs
    MHack PC Specs
    Laptop (Model)Asus Zenbook UX333 + Macbook Pro
    MotherboardZ390-F + Z370 Plus
    Processori5-9400 + i5-8400
    Memory (part number)8, 16, 16, 16
    Jun 2018
    8
    TUF Z370-PLUS and Wake on Lan
    Using the latest firmware 0805, and the embedded NIC.
    The WoL function worked fine for a few months.
    Then for some reasons, it just stopped working. No change was done anywhere on the network.
    And the BIOS option
    Code:
    Power ON by PCI-E
    is still there.
    The "magic" WoL packet goes through and reaches its destination
    Code:
    tcpdump -i eth0 'udp and port 9'
    The router connected to Internet is (has always been) correctly configured, having the MAC / IP addresses of the PC set in
    Code:
    /etc/ethers
    Is it a known bug for which a fix is expected in a next BIOS release?
    MHack PC Specs
    Jun 2018
    8
    anyone?
    (any way to change the font of the CODE tag... barely readable!)
Tags for this Thread
