Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Member Array ketschupsenf PC Specs
    Motherboardrog strix z370-f gaming
    Processori7-8700
    Memory (part number)HyperX 2x16GB 3200Mhz
    Graphics Card #1EVGA GTX 6GB 1060
    Storage #1Samsung M2 Evo 860
    Storage #2Samsung Evo 860 SATA SSD and WD HDD SATA
    CPU CoolerCorsair H100i v2
    CasePhanteks Enthoo Evolv ATX Tempered Glass
    Power SupplyCorsair CX750W
    OS various
    Jun 2018
    15
    rog strix z370-f gaming dram-led issue
    Hello i bought last november the rog strix z370-f gaming. Now i`m building the pc and the PC cant POST! The DRAM-Led on the board is always on in orange color.
    The RAM-Kit 2x16GB 3200Mhz (HyperX HX432C18FBK2/32 ) is in the compatible list for this board.
    I did all recommended procedures to solve the issue:
    - tried all RAM-Slots
    - clear CHMOS (removed the batterie)
    - removed graphic card
    - checked all cables
    - removed the cooler and checked cpu for pins
    Nothing is working, it shows always straight the DRAM-Led!
    Maybe its the BIOS? I guess the board where i bought last fall has an older version and maybe an newer will solve the problem?
    Could the 3200Mhz RAM be the issue?
    Has maybe someone the same RAM whit the same board running?
    Thanks for any advise
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD Samsung 960 EVO 256GB
    Storage #2SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 1903/19H1/18362.x
    MoKiChU's Avatar
    Aug 2013
    101
    338
    Which BIOS version is your motherboard ?
    Version 0614 brings an improvement in memory compatibility :
    Version 0614
    2018/04/09 - 8.22 MBytes
    ROG STRIX Z370-F GAMING BIOS 0614
    Improve memory compatibility.
    The latest version of BIOS is version 0805 released on 2018/06/08 :
    Version 0805
    2018/06/08 - 8.23 MBytes
    ROG STRIX Z370-F GAMING BIOS 0805
    Intel New ME Update, Improve Stability.
    Download : http://dlcdnet.asus.com/pub/ASUS/mb/...-ASUS-0805.zip
    Processori7-8700
    OS various
    Jun 2018
    15
    Hello
    How can i check the Bios Version?
    Cant boot or POST?
    And is it possible to update the BIOS without POST?
    ps: sorry i am a long time mac user switching now to PC
    thanks for your help
    Processori7-8700
    OS various
    Jun 2018
    15
    has this board the Asus USB BIOS Flashback Feature?
    i saw it on a website listed?
    https://www.elive.co.nz/asus-strix-z...otherboard.php
    how can i update without boot?
    Processori7-8700
    OS various
    Jun 2018
    15
    im still stuck on the dram-led!
    could i maybe solve it with a lower Mhz RAM Stick?
    to boot and update the BIOS?
    thanks for any advise
    ROG Guru: Orange Belt Array chevell65 PC Specs
    chevell65 PC Specs
    MotherboardROG Strix Z370-H, ROG Maximus VII Z97
    ProcessorIntel 4790K 4.6GHz, Intel i5 8400, Intel e8600 Wolfdale, Intel Q9650 Yorkfield, Intel E6750 Conroe
    Memory (part number)16GB G.Skill PC3600
    Graphics Card #1GTX 660 OC
    MonitorAsus 23"
    CaseCorsair clear case
    Power SupplyThermaltake
    Keyboard Logitech G15
    Mouse Logitech G9
    OS Windows 10 Pro
    Network RouterDLink DIR-655, Asus AC88
    chevell65's Avatar
    Oct 2014
    56
    363
    What are you using for a hard drive? Are you using M.2 or SATA SSD or maybe PCI SSD? You should fill out your system specs if you want more help.
  7. #7
    Processori7-8700
    OS various
    Jun 2018
    15
    here are my components:
    • Power supply Corsair CX750W
    • CPU Cooler Corsair H100i v2
    • CPU i7-8700
    • Samsung M2 Evo 860 / connected
    • Samsung Evo 860 SATA SSD and other HDs / disconnected
  8. #8
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,783
    Try posting with all of your USB peripherals (and drives) disconnected and with just one stick of memory in the furthest slot from the CPU socket.
    Recheck the CPU socket for bent or broken pins.
    If you still can't post, I would be looking at the PSU as the possible issue.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
  9. #9
    Processori7-8700
    OS various
    Jun 2018
    15
    ok thanks for your advise.
    i will try and give a feedback
  10. #10
    Sep 2011
    89
    1,783
    Quote Originally Posted by ketschupsenf View Post
    And I mean all drives, including the drive that Windows is installed on.
    NZXT Kraken X42
Tags for this Thread
