Zenith extreme faulty led in IO cover SOLVED
Tekred
So my brand new zenith extreme motherboard works great until I noticed the led in the io shield is only showing orange. Everything else works, is there anywhere I can buy this little pcb?
74221
OK so looks like someone at Asus plugged the cable into the wrong place, if anyone else has this issue, remove the IO shield and check the cable. Mine was plugged into the WB_SENSOR (pink) , plugged it into LED_CON2 (green) and everything is back to normal. I hope this might help someone else with this issue
74237
0 REPLIES 0
